steady white smoke/dripping fluid from exhaust
Old May 29, 2001 | 04:42 AM
Black Beauty's Avatar
Car: 90 Camaro RS
Engine: 305 TBI
ok, im runnin hooker LTs, with a mufflex y pipe, and i started it up today and watch the exhaust and i noticed steady white smoke, and saw fluid dripping out and tasted it and it had no flavor so i dont think it was gas.
im not runnin antifreeze, do i have a cracked block, head or gasket or similar?
will this hurt my cat?
i also examined my old cat back and it was THOROUGHLY rusted within!!! it was a weird patchy rust....so i may have had this problem for sometime.
thanks for your help!
Rick
90 Camaro RS 305 TBI
Hooker 1 3/4 LTs, Random Tech Cat, Flowmaster 80 series
406 DFI on the way
MacEwen Motorsports White Gauge Overlays
14" K&N X-Stream Open Element
"Just because I've done it, doesn't mean I knew what I was doing!" - Me
Old May 29, 2001 | 05:25 AM
IROC KID's Avatar
Sounds like a head gasket,but i will leave this to the pros.
www.rearman.com/camarokid.htm
If it aint a V-8 that $hit aint fast!,unless its a GN,lol!
305 tpi,700r-4 with shift kit,My mods are minimal,just a bunch of little $hit.Anyone know where to get underdrive pulleys for a v-belt set up?
Old May 29, 2001 | 06:54 AM
JoelOl75's Avatar
Car: 88 Firebird WS6
Gas has a pretty good flavor
Old May 29, 2001 | 11:26 AM
camaro1j's Avatar
Car: 92 Camaro
Engine: 406 sbc
Axle/Gears: 9" ME with 4.56 gears
If you have cat on your car it is probably water.
Old May 29, 2001 | 11:49 AM
sleeper's Avatar
Time to mix some coolant into your rad. Run the car with the new mix and smell the exhaust... if it smells like coolant then you need to find the engine leak.
Old May 29, 2001 | 12:07 PM
NavyVette's Avatar
Sounds like a blown head gasket allowing coolant (in your case straight water) into the combustion chamber. The white smoke sounds like steam and it's condensating in your exhaust pipe causing it to drip out. That would explain the rust also. Do a compression check and see.
Jeff
Old May 29, 2001 | 01:25 PM
Polecat's Avatar
Have you noticed a lowering of the water level lately? Do a compression check and watch the water level. If it goes down after several days, bet you have a blown head gasket or worse.
350 4 bolt main, Speed-O-Motive 383 stroker kit, re-sized rods ground for clearance,TRW Forged pistons,10.7:1 compression,HPC Coated RPM intake, Holley 750 cfm carb,World Products Sportsman II heads,2.02/1.60 valves, Comp Cam 1.6 roller rockers, Comp Xtreme 284 cam,240/246@.050 with .540 lift,Crane pushrods,ATI damper,Proform HEI and MSD6A box,HPC coated 1 5/8 headers, 2.5" exhaust with 40 series mufflers,TH350 with Hughes 3000 stall, Powertrax NoSlip Locker, 4.11 gears.
Old May 29, 2001 | 01:36 PM
FastBroker's Avatar
Do a leakdown test, if possible. Better diag tool than a std compression check. Plus, you'll get a better feel for the overall condition of the valve and ring condition.
Hotrodboba400
Dec 10, 2019 07:07 PM
db057
Apr 28, 2019 07:45 AM
83 Crossfire TA
Jan 3, 2016 01:26 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
masonta
Sep 1, 2015 06:40 PM
