Is this ok Temp for tranny fluid?
Old May 28, 2001 | 06:52 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
i have a 700R4 and an autometer guage. I also have a tranny pan with tubes running thourgh it. Suppose to be a cooling mod also I have a tranny cooler and an external tranny filter. The car shows 160* when hot and sitting and 125* on the highway cruising. Is this ok?
Old May 28, 2001 | 10:04 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
btt
Old May 28, 2001 | 10:07 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Seems a little cool from what I remember...seems to me the "ideal" (take it for what it's worth) tranny temp is 180-185.
I read somewhere that for every 10* rise over the 180-185 temp, the tranny fluid's life decreases by some factor..25%, or something like that.
Not sure if it's an issue running cooler.
Old May 28, 2001 | 10:08 PM
Guest
Guest
Posts: n/a
160 is about as cold as you want to be. 125 is too cold.
Old May 28, 2001 | 10:12 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
damit. I can never win Now what do I do? Is my guage off? Its a brand new autometer Pro Comp.
Old May 28, 2001 | 10:13 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
BTW the sensor is after all the coolers. So would it be like 180* going in?
Old May 29, 2001 | 01:00 AM
idrag2's Avatar
Why don't you want your tranny to run as cool as possiable?????
Old May 29, 2001 | 09:39 AM
406TPI's Avatar
Car: 1985 IROC-Z
Engine: Magnacharged LS1
Axle/Gears: Ford 9" 4:11's
180 is about where you want it to be. Running it too cold is almost as bad as running it too hot. The temp should be taken with a sensor mounted in the pan.....that is where the temp will be most stable.
Old May 29, 2001 | 11:29 AM
dhirocz's Avatar
Car: '86 IROC-Z/'94 Z28
Engine: 350 LT1/382 LT1
Transmission: 4L60-E/T-56
Axle/Gears: 3.45/3.42 (soon 4.10)
I had a problem with this. The problem with the fluid being too cool is that it's thicker. My car wouldn't want to shift in the morning during wintertime because the fluid was thick. I had a fairly large cooler mounted up front. Solution...instead of running the cooler from radiator to cooler to trans, I ran it from cooler to radiator to trans. I guess if it's bad enough you can run it cooler only. I know they sell thermostat's for those. I agree, 180 is the best temp. My trans worked best there.
Old May 29, 2001 | 12:00 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
It says to run sensor after the coolers inline.
Old May 29, 2001 | 02:37 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Mkos, you could cover 1/2 of the aftermarket cooler with a thin piece of sheetmetal... maybe punch some holes in it to allow for some airflow thru the "shield". I think that would cut your trans cooler in half and maybe give you the extra few degrees you need.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old May 29, 2001 | 09:30 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Hmm maybe i'll try that Thanks
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
meeklay812
Oct 1, 2015 03:46 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
mfp189
Sep 27, 2015 09:25 AM
ironbmt
Sep 27, 2015 06:00 AM
