82 vette ditributor?
Old Nov 11, 2004 | 04:33 PM
megaracerx's Avatar
i just went to pick up and new ignition moduel...and i went to buy it for my 305...(so i thought...thats what the previous owner told me) but the one that was on the shelf for my 305 is the wrong one..so i bring the old on up to match it up...and booom it matches the "82 vette" moduel...so can a vette distibutor fit on a 305? or could my engine be a 350?
and where can i find the casting numbers to check?
Old Nov 11, 2004 | 04:42 PM
THEGENERAL's Avatar
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
Re: 82 vette ditributor?
the casting numbers on the block are behind the drivers side head on the back of the block you can take a flashlight and look back there and write down the numbers you see then go to www.mortec.com and check to see what you have
as for the distributor a small block chevy distributor will fit into any small block chevy ....
it doesnt necessarily make your engine a vette engine it merely means that someone most likely swapped out distiributors at one time
Old Nov 11, 2004 | 04:47 PM
megaracerx's Avatar
Re: Re: 82 vette ditributor?
thats whqat i thought, just wasnt sure.
Old Nov 11, 2004 | 05:06 PM
nsimmons's Avatar
All 82 vettes were crossfire. I dont believe the dizzy will work on a cc qjet setup. I had an 84 crossfire vette, the same setup and to set the timing i had to disconnect a single tan wire. CC qjets have a multiple wire harness to disconnect, so thats one difference right there.
Old Nov 11, 2004 | 05:55 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
Many of these modules are pretty univeral, fit several different models. Could be the same for a truck as a Vette.
Old Nov 11, 2004 | 06:31 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
There are three different modules. A 4 pin, a 7 pin, and a 8 pin. Thats the only difference.
Old Nov 11, 2004 | 08:17 PM
megaracerx's Avatar
mine is a 7 pin, does that mean anything?
Old Nov 11, 2004 | 09:20 PM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
Yes its an 80-95 computer controlled distributor.
Old Nov 11, 2004 | 09:35 PM
vejatabul's Avatar
Car: 1988 gta
Engine: 5.7
Transmission: turbo 350
smallbock and bigblock distributers interchange, so long as they are not a tall deck.ive modified a few 87+ small cap external coil dist. to work with an msd box and they work great. one of them is on a freinds 468ci bbc. very very very inexpensive.the only parts in the modified dist is a pick up and it ties dirrectly into the magnetic p/u on the msd.
FormulasOnly
Jul 23, 2018 08:47 AM
BDR
Nov 7, 2015 03:05 PM
R13_Braz
Sep 18, 2015 05:00 PM
WickedBowtie
Members Camaros
Sep 17, 2015 09:13 AM
WickedBowtie
Sep 11, 2015 11:24 PM
