Blower on 305?
Old May 30, 2001 | 09:18 PM
92blackbird's Avatar
Car: 1992 pontiac firebird
Engine: 305 tbi
Blower on 305?
I have an opportunity to get a underhood blower set up. Either a Paxton or Vortech. Has anybody done this on a TBI 305? What were the results. May be a cheap fast way to a lot of H.P.
'92 firebird t-tops
305tbi,670cfm tbi, 2 1/2" Dynomax catback, 9x3 K&N open element
Old May 31, 2001 | 01:23 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Personally, I don't think that would be possible on a TBI car.
Besides, if you are able to run the tubing, will you have enough clearance to close the hood.
If the blower is cheap enough I'd recommend converting to TPI, that is what I am in the process of doing. I'll be adding a blower in a year or two, it all depends on cash flow.
High Speed Run: 157mph
Best 1/4 mile run: 14.94@91.67mph
WS6 Trans Am.
View My Ride @ thirdgen.org
Old May 31, 2001 | 09:52 AM
soulbounder's Avatar
Car: 89 TTA
Engine: Turbo 3.8
Transmission: 200R4
By "blower" you do mean like a turbo huh? Sorry, when I think "blower", I think big ole' super charger sticking out of the hood. I'm pretty sure you can run a turbo setup with TBI but you'll probably have to be innovative. I don't think you would have enough room with the stock hood either.
Old May 31, 2001 | 05:12 PM
86SCBNJ's Avatar
go for it. I know paxton used to make a bolt on supercharger for TBI F-bodies.
Old May 31, 2001 | 05:18 PM
Pukka's Avatar
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
They still do....saw it in a magazine....cost was pretty expensive, but the install looked straight forward. I think you need a hood with more clearance though
Old May 31, 2001 | 07:14 PM
JPrevost's Avatar
Car: 91 Red Sled
You don't have to convert to TPI, it's not going to halp much considering the Lo3 is the problem, not the intake system! The peanut cam isn't going to make much power and that is the only reason TBI gets a bad name. Anyways, you will need a TBI/carb "bonnet". It's a cap basically. If you can get the S/C cheap, go for it, you won't be sorry. Just don't run too much boast (4-5) because the Lo3 has 9.5:1 compression and cast pistons.
, Jon (350 TBI!)
91 Red My website
Old May 31, 2001 | 08:25 PM
Engine: 305 tbi
Thanks for help. 86 is right is is a Paxton kit for tbi. I should be able to get fo about 1/3 the new price. If anybody has experience with one I'd like to know what problems you ran into and how big a power gain you got. the old articles I could find talk of gains in the 75hp to 100hp range w/no other mods. We'll see maybe!
'92 firebird t-tops
Old May 31, 2001 | 08:27 PM
Engine: 305 tbi
As a follow up Paxton and Vortech are called centrifigal superchargers. The type your used to seeing are "roots" type superchargers. This are the big "GMC" truck type blowers modifies for auto use.
'92 firebird t-tops
GouldyGTR
Sep 7, 2015 09:05 PM
Stryker412
Sep 7, 2015 09:11 AM
TBRays98
Sep 6, 2015 05:05 PM
Formula_88AE
Sep 3, 2015 01:47 PM
willyjoejr
Sep 3, 2015 09:26 AM
