Just thought i'd share this
Old Nov 28, 2004 | 01:00 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
In my fluid mechanics class the other day at university, our prof put up this picture to emphasize fluid flow properties.
It kinda proves why factory vehicles usually have the air intakes behind the headlights (high pressure distribution), and why cowl induction would be a good idea. This is just a generic "car", but most cars share the basic same shape, so it gives the idea...
Thought i'd share this neat little tidbit of information, I think it was done with a CFD program of some sort.
Old Nov 28, 2004 | 01:06 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
i dont know what im looking at.
Old Nov 28, 2004 | 02:00 PM
kevinc's Avatar
Car: 1982 Z28
No need to apologize.
Sonix: that's a great visual!! With the price of CFD software coming down, hopefully we'll be able to gin up a 3rd gen model and start tweaking air splitter and rear spoiler designs.
Old Nov 28, 2004 | 03:50 PM
CaysE's Avatar
It's the amount and direction of air pressure along the surfaces of the car.
Old Nov 28, 2004 | 09:40 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
oh i totally see the car now. thanks!
Old Nov 29, 2004 | 10:21 PM
Vader's Avatar
"Average car?" It looks more like the profile of a '68 Chrysler Newport. I haven't seen a windshield that upright on a passenger car since the early '80s (except on Ford Crown Vics).
If you can, flow this. It has a frontal area of 19.2 ft², a cD of 0.27, overall height of 53.8", and ground clearance at the front and sides of 1½":
Old Nov 29, 2004 | 10:31 PM
Sonix's Avatar
Car: 1982 Trans-Am
what is that? like a '90 Thunderbird supercoupe (rear end at least) with '96 Impala wheels...
hmm, i'll see if I can get ahold of that CFD software, maybe they'll let me play with it...
I'd probably need more info too, and I prefer metric personally
Old Nov 29, 2004 | 11:01 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
That pic PERFECTLY shows how a cowl induction hood works!!!
Nice find!
Old Nov 29, 2004 | 11:15 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
excellent flow chart, it shows it perfectly
Old Nov 30, 2004 | 12:21 AM
Black 91 Z28's Avatar
Car: 1991 Camaro Z28
Here is a pic of the G35 we did where I work. The top left pic shows the surface pressure. Redish tones indicate high pressure. The pic in the middle shows the path of a particle flowing by the car. The top right shows a pic of the cad model.
Before it's asked...
No, I can't do your car. I'm still trying to do mine!
Yes, I did work on some of it.
Old Nov 30, 2004 | 12:24 AM
Heres another pic. This one shows the velocity of the air around the car at the centerline. The arrows indicate the direction. In this one redish tones indicate high speeds and greenish tones indicate low speeds.
Check out the Gallery section here for more pics of some of the stuff we've done if you're interested.
http://www.erc.msstate.edu/simcenter/
Mississippi State University Engineering Research Center
Old Nov 30, 2004 | 05:47 AM
1320 Right Ln.'s Avatar
That's pretty cool stuff. One question I have though, is why would you go through all the effort and time to make a CAD model of the car, then use a program that calculates/estimates the flow of air...when you could just take the actual car n' stick it in a wind tunnel and get real results? I don't know a whole lot about R&D, so this may seem like a stupid question... but it just seemed logical to me. I'd love ta learn how to use CAD software though.
Old Nov 30, 2004 | 07:07 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
besides the fact he is learning this in his class?
Old Nov 30, 2004 | 08:21 AM
Say your a big racing company and you want to put a spoiler on your car. You can take your car and put a wing on it and run it in a wind tunnel. If you don't like the results then you strap another one on it and go at it. Depending on how fast your machine shop is that could take a while. But with CFD you can stick a wing on there and run it. Then draw another wing real quick and run it again.
With everything being created in computer first anyway it decreases R&D time because you don't have to create the prototype and test it. You just run CFD on the computer model.
Old Nov 30, 2004 | 01:23 PM
Sonix's Avatar
Car: 1982 Trans-Am
also wind tunnel testing is very expensize... the University of calgary can only wind test things up to the size of a go-kart for example. It usually gives a good indication as to how a wing/spoiler/front air dam will react with a given shape, then you can tweak it later.
Old Nov 30, 2004 | 01:32 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Black 91 Z28:
What software are you guys using for the CAD, and for the CFD analysis?
Old Nov 30, 2004 | 04:53 PM
Originally posted by ME Leigh
Black 91 Z28:
It's all inhouse stuff that we (well them) have developed. For CAD stuff we use SolidMesh, for solutions U2ncle, and for the pretty pictures DIVA.
Old Nov 30, 2004 | 05:52 PM
Vader's Avatar
Well, you're partly right. It has 17" SS wheels, because it is one of them:
Old Nov 30, 2004 | 06:03 PM
305q_ta86's Avatar
Car: 1993 Nissan 240sx
Engine: Turbo KA24DE
Transmission: 5 spd
Axle/Gears: 4.08 VLSD
..So THAT"S why people dont have their air intakes on the roof...
(and, come to think of it, why roof scoops are a bad idea :P)
nice find!
Old Nov 30, 2004 | 10:33 PM
Air_Adam's Avatar
nice find!
I dunno... McLaren uses one on the F1 road cars and road racing cars, so it must serve some purpose?
87v6Bird
Jul 1, 2018 04:12 PM
87v6Bird
Brakes
Oct 4, 2015 07:37 AM
WickedBowtie
Members Camaros
Sep 17, 2015 09:13 AM
WickedBowtie
Sep 11, 2015 11:24 PM
IROCZ1989
Sep 4, 2015 11:54 AM
