Oil filter broke and the flange is now stuck!
Old Jun 6, 2001 | 05:24 PM
Golden80's Avatar
I got the car 3 months ago and decided to do an oil change today. Whoever last put the oil filter on overtightened it. And now I have the bottom part of the filter in my hands and the flange is stuck. Does anybody know of a good way to get this thing out or am I going to have to have the car towed?
Thanks,
Matt
Old Jun 6, 2001 | 05:27 PM
mrgto's Avatar
Take a screwdriver and a hammer and CAREFULLY tap the part of the filter that is still on the engine. That should help to get it off. Make sure the gasket comes off too.
Old Jun 6, 2001 | 08:11 PM
Enkil's Avatar
My question is.. What in gods name did you use to take the filter off with?
89 iroc-z 305 tbi
k&n filtercharger, open element air filter. nuffin' else
Old Jun 6, 2001 | 08:48 PM
Golden80's Avatar
Oil filter wrench...which is probably what was used to install the blessed thing. I used all of my brute strength (for a 5ft 3in 115lb weakling) and the thing split at the top. After that everytime I used the wrench it would just rip it off the flange. This will be the last Fram oil filter this car ever sees.
Matt
Old Jun 6, 2001 | 09:00 PM
jms's Avatar
jms
Don't take this the wrong way.
Which direction did you turn the filter to take it off?
To remove the filter you need to go in a counter-clockwise direction when you are looking up at the bottom of the filter.
Again, if you went the correct direction, don't take it the wrong way---I've done way worse!
jms
Old Jun 6, 2001 | 09:08 PM
Golden80's Avatar
Opposite direction of the arrow...right?
Matt
Old Jun 6, 2001 | 09:21 PM
jms's Avatar
jms
I don't recall an arrow. Just go in a counter-clockwise direction when you are laying under it looking straight up at the filter (or what remains of it).
I've had tough ones myself. The long screwdriver trick mentioned in one of the above posts does work but remember ---counterclockwise.
jms
Old Jun 6, 2001 | 09:25 PM
Golden80's Avatar
Wish that would work. The only part of the filter remaining is the flange. The very top part that is blocked now by the engine block. I think what I'm going to do is drill holes parallel to the oil filter adapter and try and pop it off there.
Matt
Old Jun 6, 2001 | 10:40 PM
Guest
Guest
Posts: n/a
The flange has holes in it, you should be able to get in there from at least one spot and tap a screwdriver with a hammer against the holes in the flange in the correct direction to get it off of there.
Old Jun 7, 2001 | 01:46 PM
82camaro's Avatar
Car: 82 camaro SC
Hammer, chisel, and some patience will remove it.
82 camaro--original steering wheel, brake/gas pedals, seats--everything else modified
82camaro
Old Jun 7, 2001 | 09:17 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
<font face="Verdana, Arial" size="2">Originally posted by Golden80:
...This will be the last Fram oil filter this car ever sees.
Matt
</font>
Funny.
And I popped in here to ask if you had used a Fram. They suck.
"Question with boldness even the existence of a God; because, if there be one, he must more approve of the homage of reason, than that of blind-folded fear."
-Thomas Jefferson
Old Jun 8, 2001 | 01:41 AM
Golden80's Avatar
Ok...got the little sucker off. Required a hammer, a chisel, and a pry bar. Now the oil filter adapter threads got stripped to he\\ and I'm on my way tomorrow to buy a new adapter. At least I got that thing off. A huge relief.
Matt
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
carattini
Sep 10, 2015 07:46 AM
tgp1990
Sep 4, 2015 06:24 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
