spark plug question
Old Dec 7, 2004 | 03:06 PM
85cmroz28's Avatar
Car: 1985 Camaro Z/28
Engine: L69
Axle/Gears: One-Wheel-WOnder 3.08
spark plug question
I'm getting ready to replace my spark plugs and I was just wondering if anyone had a easy method of removing them from these cars. It seems like the heater box really gets in the way of that #8 plug. Where should I go in from? Your advice is appreciated.
By the way, I have a 305.
Old Dec 7, 2004 | 03:07 PM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
I do all of them except #1, 3, and 5 from underneath the car - much easier!
Old Dec 9, 2004 | 11:41 AM
fazool's Avatar
Yep, bottom is better. Althoug, on my original motory (305), I could do all the plugs except 6 and 8 from the top (with just a little bit of cursing). I needed one extra joint in my arm to handle #6 and #8 plugs.
Now I have vortec heads - let me tell you the joys of changing the plugs! The plugs are straight, the headers are in the way, and each plug needs a different strategy. Some I can get from the top, some from the bottom. Some I can use a universal socket, some I can't. Some I have to use a socket, but need to put a box wrench on it. Oh yeah, and the box wrench needed to be cut short because too much stuff in the way. Oh joy, oh joy :-)
Old Dec 9, 2004 | 03:21 PM
BIGJON's Avatar
Car: 1989 Formula 350 Firebird
Transmission: 700 R4
I just ripped my heater box out and replaced it with a non-ac box......that got rid of it all....
But in your case yes from under the car is the best area to reach the other plugs.
Old Dec 9, 2004 | 04:25 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
What he said.
Old Dec 10, 2004 | 11:21 AM
mightymaro94's Avatar
y'all dont even wanna hear the crap i go through to change plugs, kinda like the guy with the box wrench but worse, i bought some accel header plugs, crap!!! and they still hit the header, then to put the wires back on you gotta twist and turn and really manipulate the wire boot, im sure thats good on wires too let me tell you.
Old Dec 13, 2004 | 01:33 PM
Ukraine Train's Avatar
Car: '87 Camaro LT
Engine: 355 L98
I took a plug socket and cut about a half inch off the end to shorten it and I turn it with a wrench. With my headers I can do all the plugs like this easily.
Old Dec 13, 2004 | 01:38 PM
vernw's Avatar
I cut a lot more than that off mine, it's only about an inch to inch and a half long! If you do this make sure to cut the socket on the plug end (front) and use a socket with a hex end by the ratchet connection. I even inserted some little magnet pieces from a magnetic spark plug socket so it won't fall off plugs while I reach for the 3/4" wrench.....
WORKS GREAT!!!!!
Old Dec 13, 2004 | 06:20 PM
Tremo's Avatar
Car: 88 IROC-Z - original owner!
Engine: LB9 with K&Ns, MSD, Foil, Taylor
Transmission: WC T-5
Axle/Gears: BW 9-bolt, 3.45 posi
I get to most of my plugs from under the car. Get yourself some ramps or jackstands and have at it. #8 is actually easy to reach from underneath. I think I change 1, 2 and 3 from the top, the rest from the bottom.
Since this operation is a PITA, last time I put in a set of platinums to hopefully stretch out the plug change interval.
Old Dec 13, 2004 | 07:17 PM
GTABANDIT's Avatar
I have also found the "exo drive " type rachet and ssockets are very handy for this.
evilstuie
Feb 28, 2016 03:33 PM
69 Six Pack
Oct 5, 2015 07:51 PM
Red iroc-z 305
Sep 30, 2015 05:22 PM
Bryan F
Aug 18, 2015 02:28 PM
