How do you remove the distributor?
Old Jun 8, 2001 | 01:32 PM
ArnoldBraker's Avatar
I need to remove my destributor so I can change the pickup coil. It tested infinite between the two leads. I have never pulled a distributor before and my Hanes isn't very clear. Any tips would be greatly appriciated.
Old Jun 8, 2001 | 02:06 PM
84TransAm's Avatar
It's held in by 1 bolt. Take the bolt out, disconnect the wires, and pull it straight up. That's it. Be sure to mark which way the rotor was pointing.
--Steve S--
1984 Trans Am 305 LG4, 5 speed Daily Driver, Flowmaster 80 Series
Holley 600 cfm & vacuum advance
Soon: Edlebrock Intake & TES
Old Jun 8, 2001 | 03:19 PM
Steves ZZ5's Avatar
You don't need to remove the distributor to replace your coil.
The coil is located in the top portion of your HEI distributor cap under a black cover, and the cover is held on by two 1/4" hex head screws.
First, remove the two connectors that connect to the coil leads at the top edge of the distributor cap. Then remove your distributor cap which is held on by four twist-lock screws at the base of the cap. Once you have the cap off, then remove the two 1/4" hex head bolts and then pop off the cover. You'll see your coil under that cover.
86 Trans Am WS6 Black with tinted windows, ZZ4, Mini-ram, true duals, LT4 HotCam, AFR 195 heads.
***Too many other mods to mention***
"In the future, cities will become deserts,
roads will become battlefields, and the hope of mankind
will appear as a stranger"
The Road Warrior
Old Jun 8, 2001 | 03:29 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
...pick-up coil, or spark coil?
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old Jun 8, 2001 | 04:36 PM
Steves ZZ5's Avatar
Crap...I thought you were talking about the Ignition coil. Just to be sure, Just as TomP is asking, look at these links...
First, an HEI pickup coil: http://www.autoweb.lycos.com/garage/subsys/09-23d.htm
Now, an HEI ignition coil: http://www.autoweb.lycos.com/garage/subsys/09-26d.htm
Hope this helps.
Old Jun 8, 2001 | 08:49 PM
George's Avatar
Car: 83WS6TA
Engine: ZZ4
Transmission: TH350C
Axle/Gears: 3:23
To change the pick up coil I think you have take the distributor out and then remove the gear at the bottom and pull the shaft to get at it.
[This message has been edited by George (edited June 08, 2001).]
Old Jun 9, 2001 | 01:18 AM
Thanks for the help guys. I was talking about the pickup coil, not ignitition coil. What is the deal with the vacume advance in that picture of the pickup. I am not supposed to have one, right?
Arnold
Old Jun 9, 2001 | 06:29 AM
Steves ZZ5's Avatar
Arnold,
Give us the stats on your car. Is it a factory setup?
I am thinking since you aren't seeing a vacuum advance on your distributor, you have a computer controlled distributor (electrical advance).
Old Jun 9, 2001 | 08:38 AM
Yes, it's the factory distributor, so I think it has the electronic advance. Does anybody know exactly how that works? I think I could understand how a vacume advance works, but not that. Oh, I got the distributor pulled. Man, that bolt was a bitch to get out though.:-) Thanks for the help. ~ Arnold
86CamaroDan
Sep 29, 2015 10:08 PM
Gunsbee
Sep 7, 2015 07:10 PM
RyanJB
Sep 2, 2015 01:27 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
Night rider327
Sep 2, 2015 04:18 AM
