? for expert engine builders regarding pontiac 301
Old Jun 9, 2001 | 02:16 AM
5.0GTA's Avatar
I know it isnt a 3rd gen engine, but i still could use a little insight. This is regarding the little 301 that pontiac put out in the late 70's. I've been told that pontiac uses the same block for all its engines (thats why theres fighting over whether or not a 400 is a BB or SB), anyways, if they use the same size block for all their engines, how come you cant put a set of aftermarket heads on a 301 with maybe a 350 intake manifold? I know a pair of heads will bolt up, but there was never an aftermarket intake manifold made for the 301, so if pontiac used the same block for all its engines, how come you cant use a 400 intake manifold, or a Pontiac 350 intake manifold?
1988 Pontiac GTA 5.0 TPI *deceased*
*FOR SALE* MAKE ME AN OFFER
Mods: K&N Filter, Hypertech Air Foil, Hypertech Perf. Chip, 2.5in Flowmaster Muffler, Catco Hi-flow Cat
Maryland Int. Speedway Bracket Racing Trophy Winner
Best ET-15.32@88mph 2.077 60-ft.
*New for graduation*
2001 Camaro SS/6-speed
1979 Pontiac Firebird
301/2-bbl automatic
Dog slow, flowmaster true duals
Best ET-break out the hour glass
Old Jun 9, 2001 | 02:30 AM
Guest
Guest
Posts: n/a
Different deck heights... which is the distance from the centerline of the crank to the top of the engine block. The 301 is shorter, so the manifold isnt as wide.
Old Jun 9, 2001 | 03:23 AM
JoelOl75's Avatar
Car: 88 Firebird WS6
The 301 isn't a motor, it's just a good boat anchor. Don't rebuild it, get a different motor.
Old Jun 9, 2001 | 03:03 PM
5.0GTA's Avatar
LoL, i never said i wanted to rebuilt it. I was just curious. I knew a long time ago that the 301 was just a good boat anchor
301/2-bbl automatic
Old Jun 9, 2001 | 11:58 PM
irocz's Avatar
Car: '87 IROC-Z
Engine: 406 Superram/DFI
Transmission: Auto BTE 3000 conv
Hey, for the day the 301 turbo wasn't that bad of an engine. Just look at what turbo buicks were running back then and what they became w/ another decade of development. The 3rdgen engine bay was designed to accomodate a 301 turbo...I think a sfi turbo pontiac would have been a killer engine.
Dan
87 IROC-Z, 5.7,auto, 3.27, leather, !cat, Holley fpr, K&N'S, SLP 1-3/4" Jet-Hot coated headers, Accel .219 cam, Comp 1.5 roller tip rockers, $uperPITAram, Edelbrock lower intake, Holley 52mm tb, Dynomax\Flowmaster catback. Coming Soon- DFI or prom burner, Dart Iron Eagle 200cc heads, 6" rod 383 or a 406
1987 Camaro Z28 - 5.2tpi, auto, 3.73s, ram air, airfoil, ported plenum, !cat, !tbcoolant, !smog, !4th gear
1989 Pontiac 20th Anniversary Turbo Trans Am - 161,000 miles, !cat, 9" K&N - SOLD
Old Jun 10, 2001 | 12:01 AM
zerogauge's Avatar
i believe ive read somewhere that pontiac does not differentiate between SB and BB
dont believe there's any classification
Old Jun 11, 2001 | 07:19 AM
JoelOl75's Avatar
<font face="Verdana, Arial" size="2">Originally posted by irocz:
</font>
Yikes, a defender of turbos and carbs put together in the early eighties. Almost as bad as the Oldmobile Diesel 350's or the Cadillac 8-6-4 variable cylinder motors. Not picking on GM, but thats some serious junk.
Old Jun 11, 2001 | 08:35 AM
El Guapo's Avatar
Have a friend who had a 79 T/A w/ the 301. I outran it w/ my 2.8. Thats all it took to put it on my "Junk Engine" list.
Clayton
BRoss99
Aug 10, 2025 05:08 PM
jhawkeye
May 25, 2022 06:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
