How does this 383 sound?
Old Dec 16, 2004 | 01:35 PM
85camaro350's Avatar
Car: 1985 Camaro Z28
Engine: 350 carb
Transmission: TH-700-R4
10.5:1 compression
edelbrock Etec heads
248/248 525"/525" comp magnum cam
1.5 roller rockers
edelbrock rpm air gap vortec intake
holley 750 v/s
mallory distributor
how much power will this 383 have? and what do you think of the cam? I will be running a th350 with 3200stall and 4.10s
Old Dec 16, 2004 | 02:00 PM
conlinj's Avatar
if that's the solid flat tappet cam Desktop Dyno says around...
424hp@5500
440tq@4500
should try and download a copy yourself, it's all over most fileshare programs...
Old Dec 16, 2004 | 02:14 PM
Engine: 350 carb
could you give me a link
Old Dec 16, 2004 | 02:20 PM
Damon's Avatar
3200 stall? Forget the vac sec carb- put a double pumper on it. Streetability isn't going to be improved much on a combo like that with a VS carb.
Similar combo in my buddy's all steel (heavy) 72 Chevelle goes 12.2 @ 110-111.
383ci
Dart Pro1 heads (box stock) 200cc, 72cc chambers, 10:1 compression
Comp Cams XE282 solid flat tappet cam (244/252 @ .050) with 1.5 rockers
Weiand Team G single plane intake (RPM or Vic Jr. would probably work just as well)
800 double pumper
MSD Pro Billet HEI
no-name 3000 stall converter in cheap performance built TH-350 automatic
3.73 rear gears
275 Drag Radials, boxed and bushed stock control arms. 1.80 60 foot times.
That's about it. Really nothign special about the combo. No trick parts, no custom porting or machine work. True bolt-together. Carb even runs with box stock calibration- never even played with the jetting. Turn the key, rip off a low 12, drive it home.
Old Dec 16, 2004 | 02:23 PM
conlinj's Avatar
would that buddy be marc?
Old Dec 16, 2004 | 03:12 PM
ridecamro's Avatar
Car: 91 rs
Engine: 250
Axle/Gears: stock??
hey conlinj
can you desktop dyno this for me
10.25:comp ration
lt4 hot cam-218/227 .492/.492
vortec heads
rpm air gap in take-edle
750 v/s
1.5 rr
vac advance HEI
Old Dec 16, 2004 | 04:54 PM
conlinj's Avatar
Originally posted by ridecamro
hey conlinj
10.25:comp ration
vortec heads
750 v/s
1.5 rr
vac advance HEI
cubic inches? and I can't be doing this for everyone. Just look on kaza or ares that's where i got my copy...
Old Dec 16, 2004 | 06:10 PM
ridecamro's Avatar
Car: 91 rs
Engine: 250
Axle/Gears: stock??
ohh it's a 383 sorry i just don't have kazza cuase it f'ed my comp up so can you do this for me plz
Old Dec 16, 2004 | 11:09 PM
sellmanb's Avatar
Car: '86 Berlinetta
VROOOOOOM!
Old Dec 16, 2004 | 11:53 PM
conlinj's Avatar
should be pretty close to 85camaro350's just you have a smaller cam that's roller...
UltRoadWarrior9
Apr 28, 2020 10:39 PM
randy210
Oct 15, 2015 03:43 PM
Nervous2
Oct 8, 2015 10:53 PM
Blue419
Sep 10, 2015 01:03 PM
