T5 flywheel for a 400 sbc
Old Dec 17, 2004 | 12:55 AM
Igor's Avatar
Engine: 383 carbed sb
Transmission: th350
Hey guys. I once put a 350 behind my T5, using a late block and my stock 305 flywheel. But to put a 400 behind a T5 style flywheel, Iwas told the only way to do it would be to use a early 4.3L 153 tooth diameter flywheel, and have it balanced with the rotating assembly. I was told that it will have an early crank boltpatter, small diameter needed to work with T5 bellhousing/clutch, and is externally balanced.
BTW: before anyone tells me NOT to run the T5, I know, I broke 7 of them...I am just trying to figure out a way that it could be done. Thanks.
Old Dec 17, 2004 | 08:10 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
When I did that, I used a 83-85 305 flywheel, and had it "unbalanced" to the stock 400 balance spec.
UNDER NO CIRCUMSTANCES should you have it and your engine's rotating assembly bakanced together. About the last thing you want, is a one-of-a-kind flywheel that's the only one in the world that will work with your motor. It's not much fun to have to tear your motor back down and take it back to the balance shop to have another flywheel "custom"-balanced to it, when you have to replace it.
Only 7 T-5s? Must not have been much of a 350.
Old Dec 17, 2004 | 09:45 AM
Igor's Avatar
Transmission: th350
Two world class T5s, and 5 pick your part v6 trannies. Pick your part had 90 day money back guarantee.....
I don't want a one of a kind flywheel, i had this issue once before. I just didn't know what else to do with a 406 and a T5 style flywheel.
So, elaborate on how you had the 305 flywheel "unbalanced".... just have the material removed or what? thanks
Old Dec 17, 2004 | 10:01 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
An array of holes drilled around the edge.... it took maybe 8 or 10 holes, maybe ½" dia and about that same depth. This was in the lightweight L69/LB9 flywheel; not the heavy LG4 one for low-perf engines.
Old Dec 17, 2004 | 12:27 PM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
McCleod also makes a "stock" 153 tooth flywheel for a 2 piece rear main seal externally balanced small block. I got mine from Summit for my 383 SuperRam setup with a T-5 when I put it in last May....
Old Dec 17, 2004 | 04:57 PM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
read this
http://www.camaros.net/cgi-bin/forum...c/4/9551.html?
Old Dec 18, 2004 | 02:00 PM
Igor's Avatar
Transmission: th350
Thats cool for sure, I wish i knew about this part a while back...when I had a 400 and a t5 to begin with a long time ago
Old Dec 18, 2004 | 10:14 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
:yourock:
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
darwinprice
17
Oct 11, 2015 11:51 PM
Vincent135
Sep 28, 2015 10:50 PM
mfp189
Sep 27, 2015 09:25 AM
monte87cortez
Sep 26, 2015 08:10 PM
