Rocker studs too tall?
Old Dec 19, 2004 | 05:12 PM
todd200's Avatar
Car: 87 IROC-Z
Engine: 350ci
It seems as though the top section of the rocker stud is too tall. I can't properly preload the valvetrain and get the "lock" to sit any lower. I don't think the rocker bottom is touching the taper of the stud but I forgot to check. Geometry looks dead on when turning the motor over. These are ARP studs, although I don't know what part # since they came with the heads. (Trickflow part# TFS-30400003). The rockers and polylocks are both from GM Performance Parts. Any ideas? Thanks.
Old Dec 19, 2004 | 06:46 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
i think you need longer pushrods to solve that problem not shorter rocker studs.
Old Dec 19, 2004 | 06:53 PM
todd200's Avatar
Car: 87 IROC-Z
Engine: 350ci
The geometry looks good though. I agree longer pushrods would solve that problem but looks as though it would cause another.
Old Dec 20, 2004 | 10:59 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Are you using guide plates? If so, they may have moved the studs upward enough that they're now too long. Also, if you have guide plates in there and those are the self-aligning rockers such as the ones in the LT4 HOT cam kit, you MUST take the guide plates out.
Otherwise, looks to me like you need either shorter studs, or to get the ones you have milled or ground off.
Old Dec 20, 2004 | 11:10 AM
todd200's Avatar
Car: 87 IROC-Z
Engine: 350ci
I'm not using guide plates. I know the rockers are self aligning. I do have a head bolt washer under the stud since I'm not using guide plates. That was per TrickFlow instructions. I'm going to verify push rod length again with an adjustable. Thanks.
Old Dec 20, 2004 | 11:14 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
You might want to just take the washer out. But make sure the head studs don't bottom out in their holes somehow.
Old Dec 20, 2004 | 11:38 AM
Confuzed1's Avatar
Car: 83Z28 HO
Transmission: G Force 5 speed
todd200 - Not meaning to steal your post, but I have the same dilema....the set screws stick out the same way. But I'm using guide plates.
The new ARP studs are maybe 1/4 inch longer than what I replaced the old studs with . But I can get them to lock nice and tight, but they only go in a couple of threads.....so long as they lock down, will it be OK??
I suspect that there's many running their engines this way with no problems. I'm not too keen on the idea of lopping off the tops of rocker arm studs with a grinder at all. I've seen it mentioned in searches I've done on this.
I'm afraid that would leave a nice uneven suface, and the allen screw would never lock right then.
Old Dec 20, 2004 | 04:07 PM
Confuzed1's Avatar
Car: 83Z28 HO
Also, are there poly nuts that are longer I can buy to accomplish the same thing without grinding on new rocker studs?
BTTT...
Old Dec 20, 2004 | 04:29 PM
custom88camaro's Avatar
Car: 88 camaro
Engine: carby 350
Transmission: t-5 from v6 car
Yes, get some poly nuts intended for use with stud girdles, and they are longer. I think longer pushrods is the way to go.
Old Dec 20, 2004 | 06:23 PM
IHI's Avatar
IHI
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
After looking at the poly lock nuts they are very short. When I bought my Comp Pro Mags, mine were also that short as I used them to mock up the valvetrain until my stud girdle and new poly nuts came in. Pushrods were not the problem in my case as I used the same pushrods when mocking up the valvetrain to check pushrod length-which came out to be stock length pushrods. After installing the new poly nuts for use with the stuf girdle, problem solved as the set screws not lock down under the heaad of the nut.
Old Dec 20, 2004 | 07:11 PM
Confuzed1's Avatar
Car: 83Z28 HO
Thanks guys...I'll look into getting longer poly nuts then. Like I said, I'm running guide plates, Comp 1.52 roller tip rockers, 7.8 pushrods, but no stud girdles.
The geometry looks fine, so I wouldn't want to mess with pushrod length....I think that would throw everything off. Man, it's ALWAYS SOMETHING....
Old Dec 20, 2004 | 07:13 PM
todd200's Avatar
Car: 87 IROC-Z
Engine: 350ci
RB, I can't take the washer out either, the ARP studs aren't threaded all the way up to the base. Both sets I have are like that. To take out the washer I would have to counter-sink the stud hole and that would void the warranty on my heads.
Confuzed1, It might be ok leaving it like that but IF one came loose and backed out it could be bad.
I should hear back from TrickFlow tomorrow. If they send the "longer" studs with the heads then I'll get the shorter ones. If not I'll take my other set to a machine shop and have them cut down.
Thanks everyone!
Tell me about it. This rebuild was supposed to take a month, two max. The car hasn't moved in a year last month. Too much "I'll get these since thier better, oh now this won't work and I'll have to get this......"
Old Dec 20, 2004 | 07:17 PM
IHI's Avatar
IHI
I boought my girdle from BTE and love it, spring loaded in the center so setting valves is a peice of cake, I was disappointed though, catalog showed a polished aluminum peice and when I opened the box mine was anodized red still works the same though LOL
http://bteracing.com/OnlineCatalog/P...ctID=858787093
Funniest phrase I've ever heard when I was fighting EVERYTHING when I built this new stuff:
"welcome to the world of racing, where everything costs twice as much and never fits"
Now how true is that LOL
Old Dec 21, 2004 | 07:12 PM
Vader's Avatar
Man, it's ALWAYS SOMETHING.... [/B]
If it isn't one thing, it's another. If it isn't another, it's one thing...
Just to verify, in that phot of the rocker, is the lifter fully seated and the valve at the fully closed position?
Old Dec 21, 2004 | 07:17 PM
Vader's Avatar
Old Dec 21, 2004 | 09:53 PM
todd200's Avatar
Car: 87 IROC-Z
Engine: 350ci
[QUOTE]
Yes. On that first rocker the cam is on base circle and adjusted to a 1/4 turn past zero and about another 1/16 after tightening the lock to really lock it down. Everything looks good except the lock sticking out so much.
Thanks.
Old Dec 22, 2004 | 10:29 PM
Confuzed1's Avatar
Car: 83Z28 HO
Well....solved!
Don't ask how, but my rocker studs are now all 1/4" shorter....
Now the lock screws lock flush with the top of the poly nut pretty much. Got em all adjusted, and tight - so I'll see how it flies!
Old Dec 22, 2004 | 11:03 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I had that problem once on just one of them. Stupid me I had it upseide down meaning the flat part where the nut sits was on the bottom and the round part was where i was bolting my nut on.
Old Dec 23, 2004 | 03:38 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
I have the same problem on my heads with ARP studs. They are the same length as stock LT1 studs from the seat up, but are longer on the bottom part.
Without washers or guidplates installed, the ARPs bottom out and don't seat all the way.
My heads didn't come with studs, so I bought ARP's, had the problem and took the stock studs off of my spare lt1 heads to use since I now have SA rockers.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
New2Chevy
Sep 28, 2015 12:35 AM
Billyadams
Sep 22, 2015 08:25 AM
355tpipickup
Sep 13, 2015 11:35 PM
