really quick manual to auto engine conversion
Car: C230 Kompressor
Engine: 2.3L Supercharged I-4
Transmission: 5-Spd Tiptronic
i have a vin G that was an automatic that im going to put in a camaro that was a vin G T5. i was reading the article on how to do an automatic to t5 swap... and in it, i saw that it requires a pilot bushing. whats the difference btwn the pilot bushing and pilot bearing? do i need both? i know the bearing goes on the block but wheres the bushing go?
Car: 4
Engine: 6
Transmission: 5
They are 2 choices of part that do the same thing.
Neither goes on the block. One or the other will be required in the back of the crank however.
A bearing is just that; it's a little roller bearing, that supports the front of the trans gear that the clutch disc sits on. A bushing is the same thing, except it's a bronze bushing, instead of a roller bearing.
Here's what a bearing looks like.
yeah by block i meant back of crankshaft
theres a tool that id need to get the bearing/bushing in right?
and what do you guys say is the general preference between the bearing and bushing?
thanks a ton for the info
thanks alot fellas... damn. way to make me feel inferior.. i have 200 posts you guys have 15K+
Car: 1992 Camaro RS 25th Aniversarry Edition
Transmission: TH-700-R4
Axle/Gears: 10 bolt with 3.23's and SLP Posi.
Id take a bushing over a bearing any day, that bearing goes to **** and its gonna destroy your clutch, pressure plate, and fly wheel. a bushing is going to just wear loose after a long time. Bushing>bearing.
Car: 1984 Camaro on steroids/ 1987 iroc-z28 5 speed.
Engine: 383 nitrous motor / poindexter 305
Transmission: Th350
I agree. Bushings can last a long, long time. And when they get worn, they dont cause catastrophic damage.
