setting rocker adjustment
Old Dec 28, 2004 | 09:48 AM
Zap Racing's Avatar
Car: 1989 IROC Z-28
Engine: L98 350--modified
Transmission: 700 R4--modified
Axle/Gears: 4:10 Posi
I know there's a formula/procedure that if U set the timing mark at 0*, there are certain cylinders that U can dry adjust the valves and then rotate to another location and set the rest of them (or some).
Can anybody refresh my memory on this?
THANKS,
Craig
Old Dec 28, 2004 | 09:52 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
With very small cams, like a stock 929 or the "peanut" cam, you can get close enough that way; but with larger cams, too many of the valves will be on their ramps for it to work right.
The easiest shortcut, although still not terribly precise, is to adjust each intake when that cyl's exhaust is just opening; and adjust the exhaust when the intake is just closing.
Old Dec 28, 2004 | 10:20 AM
Zap Racing's Avatar
Car: 1989 IROC Z-28
OK Thanks
Just wanted to get it close enough so it would run good enough so I could do a wet adjustment. Just got the heads back from getting a valve job done
"GIT-R-DONE".
Craig
Old Dec 28, 2004 | 01:21 PM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Or you can set them with the engine running..
Summet sells little oil return clips to make the job less messy too.
-- Joe
Old Dec 28, 2004 | 03:13 PM
Confuzed1's Avatar
Car: 83Z28 HO
Transmission: G Force 5 speed
Interesting....I've always had good luck setting them with the TDC NR1 and TDC NR6 method the Haynes and Chiltons manuals recommend. And that was with bigger than stock cams.
I just adjusted mine on the engine stand yesterday, and all seems well. I guess I'll know fer sure when I fire it up!
EDIT: Just a thought, but maybe it worked OK on the Comp XE cam I have in this engine because of the quick ramp rates??
Old Dec 28, 2004 | 03:27 PM
Nebu's Avatar
Car: 91' Camaro
Engine: Carbed 305
Transmission: 5-Speed Manual
why dont you set it like this? i think its the easiest way
bring #1 cylinder to TDC. tighten all rockers until theres no movement in the pushrod. now spin the engine 360° and tighten all loose rockers again. then give them all another 1/2 or 3/4 turn.
i think thats a very easy solution. its working very well for me. no noisy valvetrain or something like that
Nebu.
Old Dec 28, 2004 | 03:33 PM
Zap Racing's Avatar
Car: 1989 IROC Z-28
If U tighten the rocker when the lifter is at the top of it's lift/cam lobe--it leaves a bunch of slop when it returns to 0 lift--doesn't it?
Old Dec 28, 2004 | 04:03 PM
ljnowell's Avatar
Nebu.
You never tighten them until the pushrods dont turn at all. That is asking for a damaged cam, or worse. There are lots of threads with this process described in detail.
Old Dec 28, 2004 | 04:05 PM
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
Yup, what he said. You tighten when you feel the push rods resisting to turn.
Old Dec 28, 2004 | 04:06 PM
Nebu's Avatar
Car: 91' Camaro
Engine: Carbed 305
yes i dont mean tighten them so hard until you cant turn them anymore. just until you feel slight resistance in the pushrod.
nebu.
Old Dec 28, 2004 | 04:11 PM
Confuzed1's Avatar
Car: 83Z28 HO
Nebu.
Yeah, that's pretty much it. By the book:
Set nr1 cyl at TDC, compression stroke. Adjust IE on nr1, and E vlvs on 3, 4,8 cyls and I on 2,5, and 7.
Rotate damper 360 degrees. and adjust E 2,5,6,7 and I 3,4,6 and 8.
That's the abb. version. And you're done.
But Nebu's way sounds much slicker to me, and does the same thing!!
Old Dec 28, 2004 | 05:17 PM
blacksheep-1's Avatar
Car: 83 Z28
Engine: vortec 305 for now
Transmission: 5 speed
OK, here's how I do it.
Pull the plugs to make it easier, put the engine on #1 tdc compression. (put a rag in the plug hole, when it blows out it's on the compression stroke). Using a breaker bar crank the engine over to where the exhaust valve just starts to open, that's when you adjust the intake, Crank the engine over to where the intake just starts to close, that's when you adjust the exhaust. (on each cylinder).
Now when you're doing the adjustment, loosen the nut up until there's play in the pushrod, now by moving the pushrod up and down SLOWLY take the play out of it. (the idea here is to take the movement out of the pushrod w/o collapsing the lifter) Use one hand to move the pushrod up and down while cranking down the nut, this process is a little like having sex with a chihauha. Once the play is taken out, then crank down the nut another 1/2-3/4. Run the firing order this way, bolt the valve covers on and run the car. If you've done it right, there's no reason to readjust them with the car running unless you want to recreate the Exxon Valdez. If this is a new engine, crank the engine over by hand while using a drill to pump up oil pressure, this way you can check for leaks and insure the rockers are oiling prior to installation. If these are new lifters pump them up on a bench using a pushrod to collapse the lifter and then use an oil can to pressurize them, you can feel them pumping up through the pushrod. If it's a new cam make sure you use a cam lube like Mellings, and then I use a dab of white grease on the bottom of the lifter and then dip it in STP. Startup is hard on new cams.
There are other ways to do it, this has been working for me for 30 years.
And BTW
Old Dec 28, 2004 | 07:22 PM
Confuzed1's Avatar
Car: 83Z28 HO
I already assumed he and everyone else knew about spinning the pushrod between your fingers and tighten till you feel resistance....then 1/2 to 3/4 turns..........
And c'mon people!! Pretty much everything under the sun has been covered at one time or another here on this board...so - OK everybody, let's just quit posting all together and just do searches instead.
There's really no need to give a long-winded response and tell the guy to "do a search" at the very end. Just don't bother replying.
I'll step off my soapbox now....mods, you may now ban me.
Old Dec 28, 2004 | 07:58 PM
ljnowell's Avatar
This is something that comes up every week, and with a search this would have been answered immediately. Thats just the way things are.
Old Dec 28, 2004 | 07:59 PM
pasky's Avatar
I'll end this:
http://shbox.com/1/4th_gen_tech2.html#adjust_valves
Yea its for fourthgens, same deal.
I personally do with with the car running, much easier and I don't spill oil.
Old Dec 28, 2004 | 08:28 PM
Car: 83 Z28
Wow, I'm impressed, that's the first time I used the
guy in a post.
cool.
Old Dec 29, 2004 | 02:43 PM
rolling-robert's Avatar
Car: z-28 x2
Engine: 355ci and 305ci
Transmission: th350 and th350
Old Dec 29, 2004 | 02:48 PM
pasky's Avatar
I jsut gave a link....
Old Dec 29, 2004 | 02:55 PM
Car: z-28 x2
yeah sorry, i didnt read it when i replied, but now i did.
thanks
Old Dec 29, 2004 | 10:13 PM
ljnowell's Avatar
Originally posted by rolling-robert
This coming from a guy who posts videos of cars that arent his, claiming that they are!
customblackbird
Aug 15, 2021 10:16 PM
Mickeyruder
Sep 2, 2015 02:45 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
IrocZ'85
Aug 17, 2015 06:24 PM
