Is this a good deal on fuel pump replacment?
Old Jun 14, 2001 | 11:31 AM
chevyguy1969's Avatar
Car: 1999 Camaro Z28
Engine: LS1 V8
Transmission: T-56 6spd
We all know that replacing the intake fuel pumps on our cars are the biggest PIA in the world. Mine just died for the 3rd time yesterday coming home from work. A shop that I do business with when I need work done is offering to drop the rear end, drop the exhaust, drop the tank, replace the pump and screen with dealer GM parts, put the tank back up, connect the rear, bleed the rear brakes, re-connect exhaust, and fill up the tank w/gas and to top it all off give me a life time warranty, that way if my car eats another pump, which it probably will, it will not cost me a dime. He wanted $834 to do it all including all tax, labor, parts, etc. I know if i had more time and my rent car was not costing me $30/day I would have liked to take the tank to a radiator shop, have them weld on a brass fuel hose fitting and hook up an external fuel pump. But my car is already at the shop and he will have it back to me tommorow afternoon. What do you guys think? Do you think its a good deal even with the life time warranty. The shop is awesome and they have always been good to me, plus they have been in business almost 30 years so they are not going anywhere. Im open to all opinions.
Thanks,
Jeff
Poor college student(donations welcome ;0) with an all stock 1988 5.7L IROC-Z Hardtop, Auto. trans, white ext. w/gold accents (soon to be silver), black custom cloth interior, 4-wheel discs and G92 pkg. Car is dead stock. Has only standard Z28 power options and all the IROC performance stuff you could get. No pwr. seats, mirrors, or rear defrost.
Best run: 1/4 14.90 @ 92.7 MPH
See My Car here: http://zap.to/chevyguy1969
#3 Gone but shall never be forgotten. Long live the legacy of the man in black. RIP Dale Earnhardt "The Intimidator"
Old Jun 14, 2001 | 01:25 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Wow, $834? I'd rather drop the tank down 8 times myself than pay that once.
There's no need to bleed the brakes, unless you want him doing brake work. The axle just needs to be dropped down, aka "lowered down"- not removed- no brake line needs to be opened.
I'd wonder why you keep eating fuel pumps like that... do you run the tank down to almost-empty when you drive?
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old Jun 14, 2001 | 01:56 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Running the tank dry is the usual thing that kills them, besides age.
The TV station I used to be Chief Engineer of had several F*rd E350 vans as live trucks... one of them (I believe it was a 96) had a problem repeatedly where the gas gauge would fail, and shortly afterward it would stop running. Each time, the fuel pump would come out crispy. The photogs would just jump in it and drive it, too lazy to put gas in it, and it would run out... 2 or 3 times of running the pump for a while with no fuel to cool it was all it could take. Fortunately since we had the power to majorly embarass the dealer, they did it under warranty every time. It was still a PITA to the station though because we'd be without a live truck for a couple of days each time. We finally made a rule that they weren't allowed to drive it at less than ¼ tank, they had to fill it up at that point. We went from 3 months per pump to 2 years on the last one, after which I left the station.
ICON Motorsports
Old Jun 14, 2001 | 03:00 PM
Pukka's Avatar
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
$800 bucks is a rip-off! You can get it done with QUALITY parts for about $300 and get at least a 1 year warranty to go with it.
Stock GM pumps should last for several years (mine lasted 7). For the work you are describing, you should be getting a new set of diff gears w/posi installed too.
92 Camaro RS, LO3, 5-spd, T-tops
Performance:
K&N Open Air Filter, Edelbrock performer TBI intake, Fastchip Prom, Timing +4 degrees, Centerforce clutch, Xact 8mm wires, SLP 1 3/4" Headers (coated), Flowmaster Catback Exhaust, Z28 Grille w/aftmkt fog lamps, MacEwen white-face guages
Electronics:
Alpine 8030 Alarm System, Valentine One Radar Detector (How did I ever drive without one?), Pioneer DEH 7450 Head Unit w/6-pack CD changer, Pioneer DEQ 7600 Sound Processor, 2 Kenwood KAC-846 Amps powering 2 12" Pro Red subs, 2 Pioneer 6x9 and 2 MTX 4x6 speakers.
NEXT UP: TBI mods, 3.42 gears w/Torsen posi
Old Jun 14, 2001 | 03:31 PM
EVILFACE's Avatar
Ouch, over $800 is a rip off. I just had someone replace mine yesterday for $240 using all ACDelco parts.
There is the option of dropping the tank, or cutting a hole in the floorboard and removing the pump that way.
Evil's 88 Camaro
Stock 305 TBI Auto, Flowmaster, Full 3" Exhaust, B&M Megashifter, K&N Open Element, MAC Lower Control Arms and Panhard bar
Old Jun 14, 2001 | 08:43 PM
IROC5.7TPI's Avatar
Pass the Vaseline......
Old Jun 14, 2001 | 10:47 PM
Saywhut's Avatar
Mine went out a couple years ago when I was 1000 mi. from home in Waterford NY, so I took it to a GM dealership, it only cost $425 for everything, all new AC Delco.
Old Jun 14, 2001 | 11:26 PM
giovanhalen's Avatar
Car: 1984 Z28
Engine: 454
Transmission: Th400
You dont need to drop the tank. Cut a hole in the floor and change the pump. Then put tabs on the peice you cut out and screw it back on and seal it with silicone sealant. Your cost will not be that much and the job is not that hard. Just cut the hole big enough.
Old Jun 15, 2001 | 01:21 AM
FiReBReTHa's Avatar
GIO. dude, you are Crazy LoL,
first off. you never wanna cut panels out of our car cause the way they designed em. it should be left intact and done the correct way. even thru all my ghetto riggins. id never consider that. might i add. GAS!
And anything from walmart cant even beat out my couple of mexican friends in the back with a couple of burritos.
Later man, and keep in touch, gonna try to get a local gathering
91 FireBird 305 V-8
Edelbrock Catback,
ghetto rigged cold air intake,
"My G/f Once Wanted To Break Up Because Of Competition With The Car."
GheTTo Riggers INC.
We Make Mcgyver look Like Crap
Old Jun 15, 2001 | 02:13 AM
JoelOl75's Avatar
Car: 88 Firebird WS6
Some people's time is more important than $$$ because of the time/money balance, so...
I suggest you buy a walbro pump and have someone install that. They were prolly using the cheapest pumps they could use for the 'last couple times' so they could gain more overhead off you and get'ch out the door. Ya just have to make sure the mech doesn't need a fp for his car at the time and ****** your pump and install more junk... Trust no-one but yourself!
An AC replacement is just about gold also.
Old Jun 15, 2001 | 09:11 AM
blak92!'s Avatar
The tank cost me $130 in labor to drop and replace the fuel pump. Since 99% of garages have a lift all they need to do is let the rear hang, unbolt the panhard rod, remove the muffler, loosen the driver sid strap, and remove the passenger side strap, let the tank hang sideways which will give enough access to remove the sending unit and replace the pump.
The reason I did not want to do it myself - I was a lazy bastard that week, and I changed the tranny and clutch the week prior.
Typical mechanic scam douschbag. I would let the BBB know or some kind of entity and prosecute this dousch for consumer fraud. If he thinks he needs to do all that labor, then he dosn't need to be working on your car. F!!CKING *****, give me the shops number and I'll confront them.
Hybrid Black 5.7L 5 Speed
'95 Competition Yellow Corvette Coupe ZF6
specialized
Jun 18, 2022 09:26 AM
RazorN8
Jan 7, 2022 11:44 AM
9192camaro
16
Feb 3, 2019 12:21 AM
beachrodder
Aug 25, 2015 08:05 AM
justin57
Aug 20, 2015 07:05 PM
