est terminal
Old Dec 31, 2004 | 11:34 AM
92rsbowtie's Avatar
Car: 92 rs camaro
Engine: 305 lo3
Transmission: WC t-5
est terminal
does anyone know where i can find the electronic spark timing connector terminal E. or where the EST is located?
Old Dec 31, 2004 | 11:36 AM
ede's Avatar
ede
and you'll find a pic. should be in a loom right side firewall near heater box
Old Dec 31, 2004 | 01:28 PM
92rsbowtie's Avatar
Car: 92 rs camaro
Engine: 305 lo3
well im doing a search and i can't find a picture.does the wire go to the control module?
Old Dec 31, 2004 | 01:31 PM
92rsbowtie's Avatar
Car: 92 rs camaro
Engine: 305 lo3
this is driving me crazy, im getting code 42, and it will be idling fine, but once i disconnect the bypass (tan/black) wire, it starts running horrible, even after i reconnect it. it idles up and down and sputters
Old Dec 31, 2004 | 01:34 PM
Forshock 85TA's Avatar
Car: 85 Trans Am
Engine: 350 (CCC QJet)
Axle/Gears: 3.08 9 bolt
Mine ran like crap when the est was connected.
EST us usually found right near the brake booster, behind one relay on my TA.
BTW, is this a 305 to 350 swap? Did you change the knock sensor and module?
Old Dec 31, 2004 | 01:43 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
So, what is the static timing with the EST wire connector pull apart?
If it runs bad with the EST wire disconnected, then maybe, the static timing is retarded.
Disconnect the EST wire and turn the distributor (counterclockwise) until the idle gets better, check the static timing. The factory setting is 6* (I think). Maybe the engine will run better with 8* static timing.
Old Dec 31, 2004 | 01:50 PM
92rsbowtie's Avatar
Car: 92 rs camaro
Engine: 305 lo3
its set about 4 degrees advance, unconnected
Old Dec 31, 2004 | 02:17 PM
92rsbowtie's Avatar
Car: 92 rs camaro
Engine: 305 lo3
i advanced it to about 10 degrees (static) and it is running a hell of a lot better. it still has a little sputter in the lower rpms, but hardly any, think it could handle anymore advance?
Old Dec 31, 2004 | 02:24 PM
Car: 85 Trans Am
if its starting to feel better, then try a little more. Do you have an AFR gauge, would help a little ?
Old Dec 31, 2004 | 02:43 PM
92rsbowtie's Avatar
Car: 92 rs camaro
Engine: 305 lo3
i never thought an lo3 could accept that much advancement
L98GTA87
Oct 19, 2015 10:43 PM
J.C. Denton
Sep 21, 2015 04:23 PM
eustodp
Sep 20, 2015 05:09 PM
3rdgenkindagal
Sep 13, 2015 02:02 PM
pacoelrapido
Sep 11, 2015 02:41 PM
