Afr heads ?
Old Jan 3, 2005 | 09:33 PM
91 z28 350's Avatar
Car: 91 Z28
Afr heads ?
Thinking about getting Afr 195cc emissions legal cylinder heads and was wondering what i should get the chambers milled down to get compression ratio a little higher than stock ? Car would keep the stock pistons. form searchin i found the stock ones are 64cc so what would a 62cc chamber give me for c/r
Old Jan 3, 2005 | 09:59 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Re: Afr heads ?
A few tenths. Probably not worth the cost of milling.
Old Jan 3, 2005 | 10:13 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
On a street motor, you wouldn't notice any difference. Dont bother cutting it to 62cc.
Old Jan 3, 2005 | 11:32 PM
91 z28 350's Avatar
Car: 91 Z28
Just read on a website that the 180cc afrs outflow the old 190's. and it says the 195s are better for a 383 setup. I don't have anyplans for a 383 anytime soon so sould i just go with the 180's? will i even see a diffrence? i'll probally only do a mild cam and intake manifold and some porting to the stock plenum
Old Jan 4, 2005 | 12:31 PM
OneBadZ4U's Avatar
Car: '86 Iroc, '87 Iroc Vert
Engine: 350 TPI, 305 TPI
Transmission: T5 in both
Axle/Gears: 3.73, 3.45 both LSD's
I know I'll probally get slammed for this but, I bought the 180cc Heads. I was told by two independent tpi builders that those heads would be better suited for a 350 even with an LT1 Intake. I have not put them on the car yet. My car is still in pieces. I'm sure they will work fine.
Here is some info from my thread:
https://www.thirdgen.org/techbb2/sho...hreadid=252518
Old Jan 4, 2005 | 12:49 PM
Damon's Avatar
I don't think you're going to go far wrong with either choice. The 180s outflow the 190/195 heads by a very slight margin below .450 lift. And, of course, the smaller runners will give better velocity and probably make better low-midrange torque despite the fact that the flow is really about the same as the larger heads at modest lift levels.
If you only plan on lifting the valves .500" or less and running under 6000 RPMs or so, the 180s would probably be a better choice. If you plan on more lift than that and/or spinning the motor higher than that you would probably want the larger intake ports.
Old Jan 4, 2005 | 02:25 PM
91 z28 350's Avatar
Car: 91 Z28
Onebadz4u what size combustion chambers did u get ?
Old Jan 4, 2005 | 02:31 PM
OneBadZ4U's Avatar
I had them machined down to 60cc. I wanted to bump up my compression a little. The work was done on at AFR. They had to angle mill the heads. I didn' trust any local machine shop.
Old Jan 4, 2005 | 04:21 PM
91 z28 350's Avatar
Car: 91 Z28
So what c/r should you be running with the 60cc ?
Old Jan 4, 2005 | 08:14 PM
OneBadZ4U's Avatar
From what I understand, with the heads I'll be at 9.5 to 1. I was at 9.1 to 1 with 64cc heads. I though heck, if I'm getting aluminum heads, why not bump up the compression a little. I'm no expert though.
Old Jan 8, 2005 | 10:28 PM
91 z28 350's Avatar
Car: 91 Z28
Hmmm now what to get ? 64 or 60 i dunno
Old Jan 9, 2005 | 05:44 PM
91 z28 350's Avatar
Car: 91 Z28
What rocker arms are you using with your afr's I'm thinking about the comp cmas pro magnum rocker arms. Will these work with stock valve covers ?
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
92projectcamaro
Jan 18, 2016 08:00 AM
New2Chevy
Sep 28, 2015 12:35 AM
z28guy134
Sep 1, 2015 11:50 PM
