rockers hitting the bottom of valve covers
Old Jun 16, 2001 | 11:26 AM
speedlvr's Avatar
I was changing to better head cover gaskets when I noticed that there were grooves and almost cracks on the underside of the valve covers. They are obviously too short for the rockers and I don't have money for taller ones now but I'm wondering what the impact of having this going on could be. Thanks.
Old Jun 16, 2001 | 11:32 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Sounds like the valve covers are on backwards. They have a definite "intake" and "exhaust" side. The "exhaust" side is narrower and has more slope; if you put that on the intake side, the rockers will rub.
The oil fill should be to the rear on the driver's side, and the crankcase breather should be to the rear on the pass side.
ICON Motorsports
Old Jun 16, 2001 | 12:57 PM
speedlvr's Avatar
They are on the correct sides. By now - 3000 miles on the newly built motor - hopefully the rockers have worn a path as far as they will and they won't knock a hole in the covers. But it they do, what will happen? Is there any long term effects on the valve train from hitting on the valve covers as they have been?
Old Jun 16, 2001 | 05:58 PM
FlashGTA
Guest
Posts: n/a
Put on two sets of valve cover gaskets and seal them together with UltraBlue. You won't have anymore problems. Yes, it works, no, it won't leak, yes, I've done it, yes others have done it with no problems. It's cheap, it's quick, it's easy, it works. Oh, you'll probably need longer hold down bolts.
Old Jun 16, 2001 | 07:24 PM
87formula's Avatar
Damage could be as little as a bent pushrod and range up to a ground off lobe on the cam. I would highly suggest trying to use two valve cover gaskets and see if that will solve the problem. If not try fabricating some out of steel or wood, the worst that could happen there is you could leak(wtf cares just check your oil!). TTYL.
1987 Firebird Formula
305 LG-4
GM Vortec heads 2.02x1.6 valves
Crane CompuCam 2030
700-R4 Trans
4 barrel quadrajunk remained by holley (this carb stinks!!!)
edelbrock performer intake
Hypertech Thermomaster Chip
Open Element Air Filter
No Cat with Straight pipe (Dynomax muffler rusted apart and fell off probably could not stand the heat )
Accel H/P Coil
- Soon to be installed
383 stroker (built and ready)
NO MORE COMPUTER CRAP
700R4 Lockup kit
Edelbrock TES
True Dual exhaust or 4 inch single pipe to dual 2 1/4"
Stall convertor
Old Jun 16, 2001 | 11:30 PM
speedlvr's Avatar
<font face="Verdana, Arial" size="2">Originally posted by FlashGTA:
Put on two sets of valve cover gaskets and seal them together with UltraBlue. You won't have anymore problems. Yes, it works, no, it won't leak, yes, I've done it, yes others have done it with no problems. It's cheap, it's quick, it's easy, it works. Oh, you'll probably need longer hold down bolts.</font>
Yes, I'll try it.
db057
Sep 4, 2015 07:57 AM
Thaney9
Aug 29, 2015 03:16 PM
NBrehm
Aug 25, 2015 11:49 PM
1985chevydude
Aug 20, 2015 12:29 AM
mustangman65_79
Aug 8, 2015 01:18 AM
