replacing fuel pump
Old Jan 6, 2005 | 11:42 AM
92rsbowtie's Avatar
Car: 92 rs camaro
Engine: 305 lo3
Transmission: WC t-5
replacing fuel pump
well i found my fuel pressure doesn't hold at all, so i have to replace my fuel pump. i have a full tank of gas, does anyone know the best way to take all the gas out of my tank, to drop it?
Old Jan 6, 2005 | 11:51 AM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
Re: replacing fuel pump
I'm no expert, but I don't think you need a new fuel pump just yet. Not holding pressure? could be a number of things.
Old Jan 6, 2005 | 11:52 AM
CaptPicardsZ28's Avatar
Car: NCC-1701-D (docked in AZ)
Engine: impulse drive
Transmission: fusion reactors
Axle/Gears: Rescued from the Borg by my crew
It could be the pressure regulator or one or more of your injectors is leaking...
Old Jan 6, 2005 | 12:33 PM
92rsbowtie's Avatar
Car: 92 rs camaro
Engine: 305 lo3
no its my pump. theres a check vavle in the pump which allows the fuel line to the tbi to hold pressure for a while after motor is turned off. when i turn it off, pressure immediatly drops to 0.
Old Jan 6, 2005 | 01:14 PM
z28cmr83's Avatar
Car: 83 Z28, 84 Z28
Engine: 5.0 Cross Fire, 5.0 H.O.
Transmission: 4 Speed Auto, 5 Speed Manual
Why dont you just siphon it out?
Old Jan 6, 2005 | 02:42 PM
Benm109's Avatar
Car: 1991 Chevy Camaro
Engine: 305 TBI
You don't have to change the pump just because of that. There are a good number of guys (on the TBI board at least) that have the same problem, but the pump still works fine, other than that. How do I know?, because mine does the exact same thing, but it works fine. Since you have a fuel pressure gauge hooked up, what's your fuel pressure at while the engine's running? Should be 9-13 PSI.
Old Jan 6, 2005 | 06:19 PM
92rsbowtie's Avatar
Car: 92 rs camaro
Engine: 305 lo3
no, my car drives horrible. while under acceleration, the pressure can make dramatic drops and increases causing my motor to surge, and have little to no power. when i floor it, it does move and the pressure drops to nearly 3 psi. at idle it fluctuates between 4 and 10 psi.
Old Jan 6, 2005 | 07:03 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
fuel pumps pretty much immediately DIE, they don't gradually give out.
Old Jan 6, 2005 | 07:18 PM
92rsbowtie's Avatar
Car: 92 rs camaro
Engine: 305 lo3
unless you have a broke check valve
Old Jan 6, 2005 | 08:52 PM
Benm109's Avatar
Engine: 305 TBI
Sounds like a bad fuel pump to me. But, have you checked your fuel pressure regulator at all? It's located on the back of the TBI unit and is gold-colored. Sometimes the diapraghm (spelling?) can tear, but I can't remember the symptoms of a bad FPR.
Old Jan 6, 2005 | 09:01 PM
92rsbowtie's Avatar
Car: 92 rs camaro
Engine: 305 lo3
the regulators fine
Old Jan 6, 2005 | 09:11 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Just curious, but if you've made up your mind and want no contradictory input, why post?
Old Jan 6, 2005 | 09:58 PM
92rsbowtie's Avatar
Car: 92 rs camaro
Engine: 305 lo3
if your talking to me... read my first post, i posted asking the best way to remove the gas from the tank, i know i could syphon, but i thought someone might know a better way
Old Jan 6, 2005 | 10:01 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Ah. My bad, forgot the question by the time I finished reading.
How much is in it? I've dropped them when they were more than half full. I siphoned 'em when they were down. :shrug: Easier if you have a helper.
Old Jan 6, 2005 | 10:13 PM
92rsbowtie's Avatar
Car: 92 rs camaro
Engine: 305 lo3
my computer farted. no its cool. my tank is topped off, the problem is i am working on an incline, i would just drop the tank full with a couple jacks, but im positive my tank will roll to the road. so i would like to empty it, that way i can just lower with the help of a friend. i geuss siphoning is the only, not to thrilled about it however.... never done it ether, how do i siphon it?
Old Jan 6, 2005 | 10:19 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
If you are on that much of an incline, I wouldn't even jack the car up. If it's safe for the car, it's safe for the tank.
Put hose in, hold hose above fluid level, fill hose with fuel (make sure part of the hose is below the top level of the fluid so you don't just fill the tank ), tip into container so the hose end is below the bottom of the fluid level and sit back and relax. No smoking though.
And if I typed that coherently enough, I need another beer.
Old Jan 6, 2005 | 10:23 PM
92rsbowtie's Avatar
Car: 92 rs camaro
Engine: 305 lo3
well my driveway levels out for the location of the jack stands, but the tank is over the incline...so no sucking and filling my mouth with gas?
Old Jan 6, 2005 | 10:32 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Umm... no. That typically does not end well.
Old Jan 7, 2005 | 01:25 AM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
With the ignition off apply 12volts to the ALDL diagnostic connector terminal "G" to power the pump. I use a hand held remote starter switch, hook one side of the switch to 12volts the other to the "G" terminal, pull the trigger and hold. Stop when the flow starts to sputter because you can't get all the gas out, but more than syphoning.
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
justin57
Aug 20, 2015 07:05 PM
drewdock87
South Central
Aug 18, 2015 09:02 PM
92camaroJoe
Aug 13, 2015 06:07 AM
