Bad TPS readings.
Old Jan 9, 2005 | 04:03 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
Bad TPS readings.
I put in a new TPS not too long ago when i was trying to fix another problem I had. Today I decided to test the voltage on my TPS, and no matter how I adjust it, I can't get the voltage higher then about 3.5 v. and thats with the minimum about 1v. if i bring the minimum down to .6volts, my WOT voltage reads 2.5v
thats bad right? should I return it for another?
Old Jan 9, 2005 | 04:18 PM
Vader's Avatar
That isn't necessarily the fault of the TPS. Check the voltage across the TPS from the ECM. You should read 5.0 VDC ± 0.1 VDC. Read that voltage between the 'A' and 'C' terminals at the TPS (the gray and black wires).
If the supply voltage from the ECM is low, the TPS has no way of increasing the signal. Low supply voltage could indicate a problem with the ECM itself, but is more likely due to poor connections at the ECM, including grounding at both the ECM and engine.
Old Jan 9, 2005 | 04:20 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
thats the way i checked the voltage, was by jumping the wires at the tps itself.
Old Jan 9, 2005 | 10:14 PM
1988 Massz's Avatar
Car: Acura now/Z in the summer
Engine: 5.7 tpi
On your throttle body it sounds as if your tour tv cable may be at fault, first try resetting the tv cable by depressing the d button and pulling the kickdown cable flush with the bracket and then turn the tb to wot and you should here 3 clicks. then recheck the tps voltage again and if it is still below 3 volts then readjust the tv cable by advancing it a little. the tb plates will not open fully if not adjusted right and this will cause your low voltage reading, remeber the tps is only giving voltage according to the accelerator position. Hope this helps
Old Jan 9, 2005 | 10:50 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
i know for fact my tb is opening all the way, im doing it by hand!
Old Jan 10, 2005 | 03:17 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
Re: Bad TPS readings.
Are you doing this with the engine running? I have found that the max voltage you will get from the TPS is a little lower if the engine is off than when it is on.
Old Jan 10, 2005 | 05:41 PM
Vader's Avatar
And do you have five volts across the outer two terminals?
Old Jan 11, 2005 | 12:40 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
I dont understand your question vader, but when i tested it again today at work, idle it was 5volts and WOT it was around 8volts!! im gonna warranty it tomorrow.
92firebirdguy
Sep 1, 2016 07:53 AM
BumpaD82
Feb 26, 2016 02:57 PM
3rdgenkindagal
Sep 13, 2015 02:02 PM
earlpote
Sep 12, 2015 11:55 AM
