why is my car making that noise?
Old Jun 19, 2001 | 02:44 PM
92 z28's Avatar
hey, i have a 92 camaro, everytime i turn my steering wheel all the way to the left, it seems like something around the front left tire is making this weird continues poping noise, i have no idea what this may be. if anyone mite have a clue i would appreciate the feedback. thanks
dozer80464@aol.com
Old Jun 19, 2001 | 04:41 PM
One Eyed Jack's Avatar
my tires rub the front wells when i turn sharply. check that,.
Old Jun 19, 2001 | 06:56 PM
SS-84's Avatar
Car: 1992 RS
Transmission: 700R-4 when it works
I was wondering the same thing.
I also have a 92.
My has 16" wheels, quick ratio steering, and 245/50-16 tires, they do not rub.
But I get that popping noise every time the car is moving forward and the steering wheel is at lock.
I have changed the centerlink, idler arm and strut bearing plates. And the noise persists.
Please someone HELP US.
LOBC-- SS-84
92 RS Heritage package with a 305
84 El camino
Old Jun 19, 2001 | 06:59 PM
dacuma's Avatar
Car: 89 Irocz
Axle/Gears: 342
It might be your sway bar bushings, or your panhard rod bushings, they may be shot. So you might want to check that.
Old Jun 19, 2001 | 07:52 PM
irocbsa's Avatar
SS-84,
That popping noise is most likely a crack in the body right where the steering box bolts to the frame. Its a common problem with these cars. Take it to a certified welder and have him close it up for you.
bsa
"If they do not run, Then they will die." - Stonewall Jackson
'87 IROC, 355 TPI, Converted to SD, 700R4, B&M Megashifter, 3.42, Trick Flow Twisted Wedge Heads, Edelbrock Intake, Accel Runners, Comp Cam, Crane Gold rockers, Lucas 24# injectors, Edelbrock headers, Flowmaster 3'' exhaust, Mallory Ignition, Transgo Performance Shift Kit, Corvette Servo, 2,000 Stall Torque Converter
Old Jun 20, 2001 | 03:31 AM
SS-84's Avatar
Car: 1992 RS
irocbsa--
Thanks for the info, I will check that out this weekend.
If it is the frame that popped, and I have it welded, is there something I can do to make sure it does not happen again or will the weld suffice?
Thanks again.
LOBC-- SS-84
84 El camino
Old Jun 20, 2001 | 10:14 AM
TransAm86's Avatar
Yes there is. It's called the wonderbar. The dealer sells it for about 43$. It came on IROC's and 91-92 Z28, I think(please correct me)
Nik
Old Jun 21, 2001 | 05:49 AM
SS-84's Avatar
Car: 1992 RS
Appreciate the info TransAm86.
I will check it out.
Will the dealer know what I am asking for if I ask them for a "Wonderbar"?
B_Dubya
Aug 26, 2015 05:09 PM
BlackBoulder
Aug 11, 2015 11:15 PM
hokis
Aug 9, 2015 03:57 PM
BrianI
Aug 9, 2015 11:52 AM
