B&M megashifter
Old Jun 20, 2001 | 04:34 PM
fourspeed's Avatar
B&M megashifter
has anyone installed a B&M megashifter, any problems, how do you like it, any hints
Old Jun 20, 2001 | 05:15 PM
know_bull88's Avatar
I had problems with the handle tighting up but after a little loctite everythigs firm with no probs LOL.
Old Jun 20, 2001 | 07:27 PM
irocbsa's Avatar
The switches were a bitch to get lined up properly. I still have to jiggle the shifter sometimes to get the neutral safety switch to engage so I can start the car. Other than that it was a straightfoward job.
bsa
"If they do not run, Then they will die." - Stonewall Jackson
'87 IROC, 355 TPI, Converted to SD, 700R4, B&M Megashifter, 3.42, Trick Flow Twisted Wedge Heads, Edelbrock Intake, Accel Runners, Comp Cam, Crane Gold rockers, Lucas 24# injectors, Edelbrock headers, Flowmaster 3'' exhaust, Mallory Ignition, Transgo Performance Shift Kit, Corvette Servo, 2,000 Stall Torque Converter
Old Jun 20, 2001 | 09:40 PM
Baz89RS's Avatar
No problems at all except for what Bull88 said, the **** will turn around some if you don't lock-it down with something.
Old Jun 21, 2001 | 06:54 AM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Here's a hint, I used the stock, works great.
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
FLOWMASTER
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
160* Stat
2:73 GEARS
Rebuilt 700R4, with manual valve body
B&M Megashifter
Soon to be installed
Exhaust Cut-Out and different gears, either 3:73 or 3:42
"There is nothing more addicting than speed"
Old Jun 21, 2001 | 07:35 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
My only complaints are that the shifter cable sheathing was broken right out of the box, and that my whole console lifts up when I downshift. Other than that, I'm happy with it. It's comfortable, looks good in my interior, and works well.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old Jun 21, 2001 | 01:43 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
The only problem I've had was the same as Bull88 and Baz89- that is, if you can call it a problem. I just had to get a tube of Loctite; it's been fine ever since. My first rubber shift boot also cracked to hell; I assume it was because I Armor-all'd it. I bought a replacement from B&M, and after 3 years, it has a few minor cracks. I haven't brought Armor all anywhere near it.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old Jun 21, 2001 | 05:01 PM
CraZ-28's Avatar
Car: 1991 Z-28
Engine: Can you say stroke?!?!
Transmission: 700-r4
I had the same problem with the shifter **** but loctite cured that problem. The only other thing I found out, the HARD WAY, is to not let the shifter sit in the sun. That is if you don't mind having B&M branded into your hand backwards!
'91 Z-28 5.7, SLP 1 3/4 headers, 4 inch Mufflex/Flowmaster cat back, gutted cats, Edelbrock intake, 8.5mm Jacob wires, MSD Blaster coil, S&W subframe setup, Jacob Pro Street Ignition, complete Kenwood system.
Old Jun 21, 2001 | 05:32 PM
camaro6spd's Avatar
I have a hurst shifter and there are NO problems with it. I like it alot.
Old Jun 21, 2001 | 08:38 PM
irocbsa's Avatar
Another problem I had is that the aluiminum paint on the **** has almnost entirely rubbed off. I had originally thought that the **** was polished aluminum but it looks like they just painted it with shiny paint that looks like aluminum. What a bitch.
bsa
UltRoadWarrior9
Apr 28, 2020 10:39 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
roysatikas
Sep 22, 2015 08:15 PM
MarineIROC
Southern California Area
Sep 16, 2015 05:40 PM
armybyrd
Sep 16, 2015 07:00 AM
