Comp XE262 and Stock vortecs
Old Jan 19, 2005 | 05:30 AM
dennis6's Avatar
Car: 1991 Camaro RS
Jegs claims the stock vortec will take .475 lift. If this is true it should be safe to use vortecs with an XE 262 cam, or am I missing something?
Old Jan 19, 2005 | 05:55 AM
ede's Avatar
ede
what are they refering the springs? then maybe so but springs isn't the limiting factor with vortecs
Old Jan 19, 2005 | 12:06 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Thoretically youd have enough retainer to seal clearance, but youd still need better springs. Probably also would want to stake the studs at the very least.
Edit: Wasnt thinking, brains on vacation as usual.
Old Jan 19, 2005 | 02:36 PM
dennis6's Avatar
Car: 1991 Camaro RS
Thanks, guess its modified vortecs then.
Old Jan 19, 2005 | 02:41 PM
dennis6's Avatar
Car: 1991 Camaro RS
From the JEGS website...
Cast Iron Vortec Complete Assembly
Fast burn combustion chamber and high velocity ports combine to produce big horsepower out of the box by as much as 20-40 HP increase over earlier cast iron SB heads. Requires the Vortec style intake manifold. Fits all SBC engines 1955 to present, excluding LT1/ LT4 reverse coolant flow engines and current LS1 style engines. Comes completely assembled with valves, springs, retainers, and 3/8'' rocker studs. Requires the use of self-aligning rocker arms.
Material: Cast Iron
Intake Runner Volume: 170cc
Combustion Chamber Volume: 64cc
Vale Diameter: 1.94'' Int./ 1.50'' Exh.
Spark Plugs: Straight
Special Note: Valve Springs - .475 Max Lift
Not disagreeing with you ede, just put this out there to see what you thought.
Old Jan 19, 2005 | 04:08 PM
Nebu's Avatar
Car: 91' Camaro
Engine: Carbed 305
Transmission: 5-Speed Manual
why dont you get some pro topline vortecs for 463 dollar with screw-in studs and higher lift ability?
just a suggestion...
nebu.
Old Jan 19, 2005 | 04:37 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
The springs still aren't the limiting factor as far as lift is concerned. It is the distance between the bottom of the retainer and the top of the valve seal/guide boss. No spring, no matter what its max lift is, can change that fact as long as the factory installed height and the height of the factory guide boss remain the same.
I agree with the Pro Topline suggestion, if Vortecs are the route you are taking.
Old Jan 20, 2005 | 03:43 AM
dennis6's Avatar
Car: 1991 Camaro RS
Where do you suggest getting them from? Shaver racing heads used to be the place to go. However, it seems like they went out of buisness.
Old Jan 20, 2005 | 04:13 AM
Ray87Z's Avatar
Car: 94 Z28
Engine: LT1 w/ headers, catback, CAI, tune
Axle/Gears: 3.23s
I've been running the XE262 with untouched Vortecs for like 3 years now. No problems so far but it's pushing the lift limit. If/when I ever get some coin to spare to upgrade to 1.6 rockers I'll be swapping on the Crane spring/retainer set that is supposed to allow for more clearance between the retainer/valve guide boss without machining...
Anyway, since you're buying new it makes sense to go ahead and get a set of modified Vortecs, you'll come out ahead in the long run... But to answer your question you should be able to get away with the XE262 on the stockers as I have...
Oh and I believe www.competitionproducts.com has the Pro-Topline Vortecs.
Old Jan 20, 2005 | 05:36 AM
SLEEPER 86's Avatar
Car: 86 coupe
Engine: 383
Axle/Gears: 9 bolt 3.27 posi
just get the valve guide bosses trimmed,while you have the heads off,you might as well have the spring pockets enlarged to 1.44" for the good springs.it doesn't cost much.
Eric
Old Jan 21, 2005 | 02:36 AM
dennis6's Avatar
Car: 1991 Camaro RS
Thanks everyone, looks like I will be buying protoplines.
84z96L31vortec
Aug 20, 2017 12:16 AM
Genopsyde
Oct 7, 2015 08:35 PM
happyhapka
Aug 15, 2015 04:42 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
