Car not able to rev past 4 - 4500 rpms?
Old Jan 20, 2005 | 06:40 PM
branz28's Avatar
Car: 1989 IROC-Z
Engine: 383
Transmission: Pro-Built 700R4 2400 ACT Stall
Axle/Gears: 2.77 Borg Warner 9-Bolt
I just bought a 1992 Camaro RS 3.1L V6 with 175,000 miles. When i floor the pedal, it will rev up to about 4 - 4500 rpms and just acts like it hit a wall. The only thing thats done mechanically is MSD wires, Crane Cams cam (not for sure which), and it still has the cat. on it. with the stock muffler system. Any idea's? Thanks For any help.
Old Jan 20, 2005 | 06:54 PM
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
Fuel pressure might be dropping at WOT. I don't know much about the 3.1's, when mine took a dump I got sick of it and dropped a v8 in.
Old Jan 20, 2005 | 06:56 PM
Rick King's Avatar
Car: 1987 TA
Engine: 350 stock/twecked
dose it stlll out in park or nutural-- if so it is probly a built in rev limiter to keep it from blowing up if in gera refer to post before this one
later and
GB
rick
Old Jan 20, 2005 | 07:04 PM
branz28's Avatar
Car: 1989 IROC-Z
Engine: 383
Nope, a few months back (6 months actually) it never did it when i was looking into buying it. Back then it'd goto about 5500 rpms and shift. Now it revs up to 4500 or so and just kinda hangs there.
Old Jan 20, 2005 | 07:06 PM
305q_ta86's Avatar
Car: 1993 Nissan 240sx
Engine: Turbo KA24DE
Transmission: 5 spd
Axle/Gears: 4.08 VLSD
later and
GB
rick
He didnt mention anything like that in the mods though..?
Does it bounce, like a rev limiter will make it do?
Old Jan 20, 2005 | 07:25 PM
branz28's Avatar
Car: 1989 IROC-Z
Engine: 383
Not like a rev limiter. Just like the whole car freezes. Tach and everything just hits a wall. No bouncing. Sometimes if it revs. It revs really slow.
Old Jan 20, 2005 | 07:28 PM
305q_ta86's Avatar
Transmission: 5 spd
Any codes? If you have an a/f guage, or tap into the o2 sensor with a multimeter, maybe you can see if it's leaning out from no fuel pressure or something...
Old Jan 20, 2005 | 07:35 PM
branz28's Avatar
Car: 1989 IROC-Z
Engine: 383
Well, i can actually get my cousin to let me use his laptop and i can do a realtime log on it....Would that show enough information?
Old Jan 20, 2005 | 07:38 PM
305q_ta86's Avatar
Transmission: 5 spd
umm I'm not really sure. You're going to have to get help from someone else on that one. I would imagine it would, but only if it's collecting the right information...
Old Jan 20, 2005 | 07:41 PM
pasky's Avatar
Could be a clogged cat also.
Old Jan 20, 2005 | 08:32 PM
ZZsmpch's Avatar
I'm surprised it'll spin to 4500 with that kind of mileage on the valvesprings.
Old Jan 20, 2005 | 08:52 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
well, if it's cold out I bet your guage is off. get the lap top and see for your self then you will know if it is a guage problem first then you can go from there
Old Jan 21, 2005 | 02:07 PM
branz28's Avatar
Car: 1989 IROC-Z
Engine: 383
Well, thats the thing i had kind of wondered about. It has a crane cams cam in it and he said he used the stock valve springs. When i talked to him he said it had started doing all this about a month after he installed the cam. Which made me wonder if the cam is putting a little extra stress on the springs? Going to hook it up to the laptop tonight.
Old Jan 21, 2005 | 04:15 PM
Cooper's Avatar
Car: '89 GTA
Axle/Gears: 3.45
That'd be my guess, my cat broke internally and wedged a piece sideways, took the GTA to it's knees, wouldn't rev past 2000 in neutral. It was kinda like hittin' a jake brake at 50mph
Old Jan 21, 2005 | 04:19 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
I vote for a plug in the exhaust system somewhere.
angel2794
Theoretical and Street Racing
25
Mar 7, 2026 01:08 PM
novaderrik
Aug 10, 2015 12:44 PM
Sherpajames
Aug 7, 2015 06:56 PM
kyle5647
Aug 7, 2015 03:08 PM
