fuel filler neck
Old Jan 21, 2005 | 06:47 PM
ctr's Avatar
ctr
fuel filler neck
Can a loose fuel filler neck be fixed without dropping the tank? The car leaks when filled up, and the filler neck is loose. I checked but could not find a recall that addresses this problem for 1988 Camaros.
Thanks in advance.
Old Jan 22, 2005 | 01:41 AM
blacksheep-1's Avatar
Car: 83 Z28
Engine: vortec 305 for now
Transmission: 5 speed
I think you can remove the plastic inner fender panel and get to it. I wouldn't bet the farm on that but as I recall that's how I did it several years ago. At least you can get to some of it.
Old Jan 22, 2005 | 08:24 AM
86z/92rs's Avatar
Car: 86Z/92 RS Camaro
Engine: 357 vortec finished. need tuning
Transmission: Still works
Axle/Gears: need 3.73
Here is a picture of the plastic piece off:
Attached Thumbnails fuel filler neck-fuel-tank-removal-01
Old Jan 22, 2005 | 10:43 AM
ctr's Avatar
ctr
Thanks to both of you. The picture helps a lot. When I did a search on this subject, many of the posts said the neck was soldered on the tank. Is this correct? How can I fix it safely (and so that it will be safe)? Detailed directions would be most appreciated.
Thanks again in advance.
Old Jan 22, 2005 | 05:27 PM
86z/92rs's Avatar
If I am remember correctly, there was a recall on the 3gen f-body car regarding the gas tank. If your car has not been fixed by the recall, take it to the GM dealer and have them do it for you.
Old Jan 22, 2005 | 07:16 PM
Lo-tec's Avatar
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
Filler neck is soldered, and only way to fix it is to replace tank.
Old Jan 23, 2005 | 04:41 PM
ctr's Avatar
ctr
I checked the NHTSA website. The only two recalls that came up for '88 Camaros were 90V105000 (SEAT BELTS:FRONT:BUCKLE ASSEMBLY) and 90V115000 (FUEL SYSTEM, GASOLINE:DELIVERY:HOSES, LINES/PIPING, AND FITTINGS), but the latter concerns those equipped with the 2.8L V6.
How much is getting this fixed at the dealer going to cost?
Thanks.
<edited for grammar>
Old Mar 13, 2005 | 02:08 AM
ctr's Avatar
ctr
just a bump in case anyone has something new to add. Thanks.
Old Mar 13, 2005 | 05:04 AM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
How long have been having this problem, if it's a long time, and you're in a high humidity area water in the air is condensating in to the tank over nights, and extended periods of unuse, and will be rusting the inside of the tank including the sending unit, I'd get it fix ASAP. Be sure have a look inside before the tank is discarded.
Glowsock
Jul 24, 2025 03:15 PM
1992 Trans Am
May 10, 2023 07:19 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
mike_c
Aug 27, 2015 04:32 PM
92camaroJoe
Aug 13, 2015 06:07 AM
