new motor start up qustion
Old Feb 3, 2005 | 06:58 PM
87camaro kid's Avatar
Car: 1987 Z28
i jsut droped in a modified 350 into my origonaly 305 tpi camaro just a few qustions
1) the engine is a little hard to start at first then it turns on and puters alittle and then if i give it gas it idles fine but when i give it alot of gas after its warmed up it dies but if i just graduall give it gas it works fine
2)there is kind of a clanking sound coming from the botom end and i noticed that the balencer wobels alittle bit, i guess it didnt go on streight, could that be the noise? or the timing chain? the noise isnt very load
Old Feb 3, 2005 | 07:35 PM
IHI's Avatar
IHI
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
Sounds like a timing/distributor issue. Pull distributor out and bring motor up to TDC compression storke, install distributor and make sure it'spointing at #1 on the cap when the timing mark is on TDC mark on balancer then be sure all wires are routed correctly. Might just be as easy as the distributor being off a tooth.
Old Feb 3, 2005 | 07:50 PM
Car: 1987 Z28
yeah thats what i thought but i wasnt sure and i think my valves still have to be adjusted a little bit
Old Feb 3, 2005 | 08:06 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
If the balancer is wobbeling you need to at least get a new balancer or try pressing it on further. That could spell disaster.
Old Feb 6, 2005 | 03:06 PM
Car: 1987 Z28
well i think i found part of the problem...i ordered new accel injectors for the moror swap and jsut found out today one of them leaks a puddle of feul so i took them out and sending them back to jegs and geting a pair of SVO injectors from jegs
Car: 1987 Z28
yeah and im switching my 305 balancer onto the 350 cause i no that one is good and ill see how that goes
Old Feb 7, 2005 | 11:08 AM
Tibo's Avatar
Car: 1991 Z28 Vert
No surprise there, I had a similar problem with my Accells.
Old Feb 7, 2005 | 11:16 AM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
[Morley] You are mistaken, Accel produces nothing but immaculate and superior injector sets. If you hear anything other than that ignore it, it is a lie or misinformation from ignorant children as I am the premier authority on the subject. [/Morley]
The balancer wobbles when you view it from the side? It wasn't installed correctly. When you take it off inspect the crank snout and threads for damage.
Old Feb 7, 2005 | 12:12 PM
Car: 1987 Z28
well in this case they arent immaculate because then they wouldnt be leaking feul all over the palce
Old Feb 7, 2005 | 12:56 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
It was a joke. lol.
https://www.thirdgen.org/techbb2/sho...hreadid=271828
Old Feb 7, 2005 | 12:59 PM
Car: 1987 Z28
have any of you used Ford SVO injectors?
Old Feb 7, 2005 | 01:00 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Yes.
Old Feb 7, 2005 | 01:06 PM
Car: 1987 Z28
how do u like them... did the fight in the feul rails and manifold ok?
Old Feb 7, 2005 | 01:15 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
They fought the fuel rails and the fuel rails won...
They fit fine. I even used the locks without a problem, though it ran a tad rich.
Old Feb 7, 2005 | 01:22 PM
Car: 1987 Z28
haha sry im a horible speller
and thanx for the info
Old Feb 7, 2005 | 10:27 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Originally posted by Red Devil
It was a joke. lol.
I remember that thread, it made me laugh when I was reading it everynight that someone replied.
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
TheExaminer
Aug 26, 2015 04:59 PM
cstrobel65
Aug 15, 2015 10:19 AM
L98GTA87
Aug 5, 2015 11:02 PM
