later tpi manifold fit early heads?
Old Feb 4, 2005 | 11:03 PM
Kevs87Z28's Avatar
Car: Yellow/Black 1987 Z28
Engine: 355 Carb
what does it take to get an 87 tpi intake manifold to fit onto 86 heads?
pics and directions appreciated.
Old Feb 4, 2005 | 11:15 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
Re: later tpi manifold fit early heads?
lots and lots of work. By "lots" I mean "it bolts right up."
Old Feb 5, 2005 | 12:15 AM
Kevs87Z28's Avatar
Engine: 355 Carb
i was under the impression the angle of the bolts changed in 87
Old Feb 5, 2005 | 12:18 AM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
I only know of the bolts angle being changed for vortec style heads... I could be wrong, but I don't think so. Let me check before screwing you over.
Old Feb 5, 2005 | 12:54 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
You're wrong, he's right.
The center two bolt holes on each head are at 72 degrees instead of 90 starting in '87. Makes it easier to get a wrench on them. In order to get the '87-up manifold on '86-earlier heads, you have to elongate those four bolt holes in the base. It's not a bad idea to face them square, too.
Vortecs are completely different in bolt pattern and runner location (height).
Old Feb 5, 2005 | 12:57 AM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
I wish the smiley worked. I could have sworn...
Old Feb 5, 2005 | 03:15 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
With the right bit, it takes only a few minutes to elongate, with the wrong bit, it will take about 30 minutes to an hour.
We had the wrong bit and it took us almost an hour to elongate the 4 center holes.
Old Feb 5, 2005 | 03:40 AM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
rotozip?
Old Feb 5, 2005 | 09:13 PM
Kevs87Z28's Avatar
Engine: 355 Carb
what do you mean about face them square?
what type of bit do i use?
Old Feb 6, 2005 | 10:03 AM
Zepher's Avatar
Originally posted by Token
rotozip?
I don't know what the right bit is, but I was told if we used the right one it would be really quick.
We used a regular drill bit.
Old Feb 6, 2005 | 10:06 AM
therckid's Avatar
Car: 1986 Trans Am
Engine: 305 LB9 TPI
Transmission: 700-R4
it takes 15 minutes with a grinder, just cut the rest of the bolt seat out toward the side of the mnaifold, and the angle nolong matters at all. Wiorks like a charm. thats how i'm getting my 86 TPI on my 88 heads so....
Old Feb 7, 2005 | 07:04 PM
five7kid's Avatar
Where the bolt shoulder meets the base of these elongated holes, it will no longer be square. I've heard of angled spacers/washers to accomplish that, but never seen them. Most people don't bother, so the bolt only contacts the base on one side. The proper approach would be to mill/grind the mounting face so that it is square to the bolt.
Old Feb 7, 2005 | 08:18 PM
Kevs87Z28's Avatar
Engine: 355 Carb
oh ok i see what you mean now. i thought you meant make them square shaped instead of a circle or oval. man i totally missed that haha. on i will have it milled. thanks alot i appreciate all the help.
transaero
Aug 31, 2015 01:14 AM
86IROC112
Aug 17, 2015 02:00 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
timonator
Aug 11, 2015 09:56 PM
