Cooling Problems
Old Jun 23, 2001 | 08:51 PM
JmeierZ28's Avatar
Cooling Problems
Ok, here's the story.. When I go up a hill no matter what, it overheats..
When I am going downhill, I can be revving the heck outa it, and it stays @ the same temp.
I am missing the air dam underneath (Have been for months).. Up till now no problems with it..
Any ideas?? Thanks!
Old Jun 23, 2001 | 10:08 PM
MikeInAZ's Avatar
Car: 86 T/A
Engine: 5.0 TPI
No point in going with further diagnosis until you replace the air dam. It is critical. You are putting a load on your engine going uphill just like when you turn on the A/C.
Old Jun 23, 2001 | 11:37 PM
JmeierZ28's Avatar
Kinda figured that...
I hope they aren't too expensive
Thanks!
Old Jun 24, 2001 | 10:41 AM
MikeInAZ's Avatar
Car: 86 T/A
Engine: 5.0 TPI
Considering the $$$ they can save you it's one of the best investments/cheapest parts you can buy...... bout' 30 bucks.
Old Jun 24, 2001 | 10:49 PM
Z's r Best's Avatar
Car: '86 IROC, black and sharp
Engine: 305 tpi, bone stock
Axle/Gears: 3.42 pos w/rear db
You can get one at the junkyard. We got one off a early 80's Olds Cutlass. It is slightly wider and taller (closer to the ground) than the original. Onle 2 of the 6 bolt holes lined up, but plastic is easy to drill holes in. Bolted right up to the 83 Z for about 5 bucks and a little time and no one has ever mentioned noticing it is different than the original.
Z's r Best
Old Jun 25, 2001 | 12:34 AM
JmeierZ28's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Z's r Best:
</font>
Thanks! The ones on the Camaros are real hard to find.. Hope this turns out better!
Old Jun 25, 2001 | 12:38 AM
firbird's Avatar
i once heard that if the plastic thing is tooken off it can cause 20 deg increase
Old Jun 25, 2001 | 01:04 AM
Tom91Bird's Avatar
Car: 1991 Firebird
Engine: 383 stroker
Mike is right about the Air deflector. I ran without mine for a couple of days one time and I ran 30degrees hotter. They are very importans. I would start here and just get a new one. There cheap enough.
http://www.yearone.com/nextgenparts/.../ngbody96.html
chazman
Aug 28, 2018 03:25 PM
greenyone
Sep 2, 2015 03:39 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
masonta
Sep 1, 2015 06:40 PM
