How to go from a factory hyd roller setup to a solid roller setup??
Old Feb 7, 2005 | 11:38 AM
Slow89Iroc-Z's Avatar
Car: 1989 Iroc-Z
Engine: 350ci SBC
What do I need to make the conversion from the factory hydra roller setup on a ZZ4 shortblock to a solid roller setup? Do I need special lifters to clear the bores on the factory roller block? What about the cam reatiner plate?? Can I still use it? What timing chain and thrust button/bearing do I need??
I was going to be using the CompCams XR280R cam.
Old Feb 7, 2005 | 09:16 PM
f-crazy's Avatar
Car: Bright Red 91 GTA
Engine: CARBED LT4
Transmission: MK6
change the cam and lifters...along with the springs..since its a roller the retaining plate doesnt have to worried about
Old Feb 7, 2005 | 09:28 PM
Car: 1989 Iroc-Z
Engine: 350ci SBC
I hear you need special lifters for a 87-up factory roller block due to the lifter bores being taller?
Old Feb 7, 2005 | 10:25 PM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
Transmission: Pro-Built 700r4 w/ 3400 converter
Axle/Gears: 10 bolt w/ 3.42 gears
Should just be the lifters/springs/cam that needs to be changed...
Old Feb 8, 2005 | 12:43 AM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Yes you have to get +.300" taller lifters to clear the taller roller block lifter bores.
junkcltr
Aug 2, 2019 11:12 PM
redmaroz
Apr 25, 2017 07:14 AM
Dialed_In
Aug 20, 2015 01:45 PM
Street Lethal
Aug 13, 2015 08:28 PM
