What Valves For A Street Solid Roller?
Old Feb 8, 2005 | 11:51 AM
Streetiron85's Avatar
Car: '85 IROC
Engine: LB9
Transmission: 700 R4
Hey... I'm wondering what valves you guys are using with street S/R cams... Just like the title says.
The cam I'll be running is the Comp XR274R and the springs recommended for that are the #977 with 155lb seat pressure and 400lb+ open pressure.
The spring loads are too high for the lower end valves such as most of the street stainless valves, according to the charts I've looked at.
So an example of the next step up would be the Manley Race-Flo @about $180-$200/set and above that would be the Pro-Flo @about $300/set.
Just curious what anyone else out there is using.
Thanks... Any feedback appreciated.
Old Feb 8, 2005 | 12:15 PM
ede's Avatar
ede
hard to beat manely
Old Feb 8, 2005 | 01:12 PM
Car: '85 IROC
Engine: LB9
Question is, could I get by with the expensive ones (Race-Flo) or would I need the REALLY expensive ones (Pro-Flo) ??
Old Feb 9, 2005 | 08:10 AM
brutalform's Avatar
Using Manley in the Brodix Track 1s. We used them for their quality, and for the fact that the valve head has a concave design, and not flat, on the bottom. They were used primarily to take a bit of compression out of the engine. Used a 2.05, over the 2.08s.
Old Feb 9, 2005 | 08:34 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
could I get by
would I need
REALLY expensive
I guess that depends on what you mean by "get by" and "need" and "expensive".
I'm using Manley 11797 exhausts and 11824 intakes in one I'm building. Hard to say whether those are "REALLY expensive" or not.
Old Feb 9, 2005 | 10:34 AM
Car: '85 IROC
Engine: LB9
Thanks for the part #s
"Get by With" Means... "It Won't Break"
"Need" Means the same thing
"REALLY expensive" Means... On the high end of thier product line, compared to the expensive ones, which cost more than the cheap ones.
... So you're recommending the Pro-Flos, or that was your choice anyway.
Any other comments or suggestions?
Race-Flo or Pro-Flo ??
junkcltr
Aug 2, 2019 11:12 PM
gixxer92
Sep 1, 2015 04:32 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
Street Lethal
Aug 13, 2015 08:28 PM
