Is this a normal sound with an open element?
Old Feb 8, 2005 | 10:18 PM
david_0161's Avatar
Car: 89 Camaro RS
Engine: 305 L03 V8
Transmission: 700-r4
I just intstalled an open element and it sounds awesome when accelerating but when i let off the accelerator it sounds like a nos blow off valve...is this normal?
Old Feb 8, 2005 | 10:30 PM
305q_ta86's Avatar
Car: 1993 Nissan 240sx
Engine: Turbo KA24DE
Transmission: 5 spd
Axle/Gears: 4.08 VLSD
Probably not. First of all, are you talking about a blowoff valve for a turbo, or a nitrous purge valve?
My open element does not make any noises...
Old Feb 8, 2005 | 11:38 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Its probably just air going through the IAC passage and the throttle blades. I wouldnt sweat it.
Old Feb 9, 2005 | 03:37 PM
david_0161's Avatar
Car: 89 Camaro RS
Engine: 305 L03 V8
It seems to be comming from the passenger side...not sure what it is and im worried....doesnt sound right....
By the way how can a 4 cyl. ford taurus keep up with me? I know I have a LO3 but something isnt right there..
Old Feb 9, 2005 | 03:55 PM
305q_ta86's Avatar
Transmission: 5 spd
Come to think of it, my 87 does that some times, and i later realized I had a loose vacuum line. Maybe it's just a coincidence that it is happening now?
Maybe you're badly out of tune? That open element sucking in too much hot air? Maybe the tarus has something under the hood? Bad launch?
Old Feb 9, 2005 | 10:22 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
If its a whistling sound, thats just the throttle blades doing their thing. Your stock air cleaner was basically a 'muffler' for the intake side of the engine. You now have less 'muffler' with the open element air cleaner.
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
Wife'sCar
Sep 5, 2015 08:58 AM
wruiz
Aug 13, 2015 09:07 PM
