Gut the cat? or no cats or neither?
Old Jun 24, 2001 | 11:26 PM
Gta-Paladin's Avatar
i've got an 89 GTA most documentation i can find states this is a dual cat car yet when i crawl under i can only locate 1 what give??!?! would they be one after the other? i find it at the start of the pass door.
I just ordered a mufflex 4" and im trying to figure out if io rdered the WRONG system
needless to say im 5hitting myself.
Also what to do with the cats do i need them, i mean i dont need emmisions i've heard i need them for some backpressure, should i just get a highflow or will i get better perf out of no cat ?
Old Jun 25, 2001 | 01:21 AM
LeftTurn1LE's Avatar
They would be side by side on the passenger side of the car.
Old Jun 25, 2001 | 01:22 AM
Enkil's Avatar
Personally I like the idea of cats. I know they rob some power, but why not run cleaner?
Most of the dual-cat f-bodies I've seen have the cats before the pipes meet at the y-pipe.
89 iroc-z 305 tbi
k&n filtercharger, open element air filter. nuffin' else
Old Jun 25, 2001 | 08:24 AM
Hulk0202's Avatar
Take em off. If you want to clean the air, pickett the semis and dump trucks you have to pass so you dont choke on there fumes.
Old Jun 25, 2001 | 06:30 PM
Blueiroc's Avatar
I personally would just get the high flow cat and and be done with it....flows the same as a straight pipe and would not cut into performance although many will disagree, I have seen cars run high 9's in the quarter WITH a cat....hhmmmm 60 bux is nuthin.....do it right.
-Brian
Old Jun 26, 2001 | 04:22 PM
Macgyver's Avatar
Just for the record, Deisels don't pollute as much as you think.
A high-flow cat is ideal, but $60 is ALOT for someone that makes minimum wage, plus you gotta have it welded on, or fool with leaky slip-fit connectors..
There are NO adverse effects to the performance of your vehicle when you gut the cat, Your car will run better in most instances. All my cars have gutted cats.
You might pollute a little more, but you'll also get better gas mileage, so I say it's a fair trade.
Old Jun 26, 2001 | 09:33 PM
West Coast GTA Man's Avatar
Car: 1989 Pontiac GTA Hardtop.
Engine: ZZ4 - 350
Transmission: Garbage
I removed my cat, and have had no problems. I have an 89 GTA, and the car only had one cat on it (The original) We have no inspection here, so I took it off, and I am happy without it.
C-ya
Mike
(Gran Turismo Americano) "The Ultimate Firebird"
Smokin 1989 GTA- Bone stock except for exhaust. (no catalytic-stainless pipe into Flowmaster 2 chamber).
Old Jun 27, 2001 | 12:38 PM
Did you notice any gains?
Old Jun 27, 2001 | 09:09 PM
Engine: ZZ4 - 350
Hey GTA-Paladin, I removed the cat, and put on a 2 chamber flowmaster, and notice a little more power. It seems to run better also.
C-ya
Mike
Old Jun 27, 2001 | 09:36 PM
irocbsa's Avatar
You may indeed only have one cat. If you have a 305: I think the G92 cars were the only ones to have the dual cat setup. If you have a 350: somethings weird.
bsa
Old Jun 28, 2001 | 12:30 AM
I've got one cat, i called and confirmed with davenportracing.com ( the store thats doing the order for me and they said it's a 1 cat car... They also said it will cost money to fabricate a straight pipe to go to inplace of the ct... Is it worth it?
Old Jun 28, 2001 | 07:10 AM
Engine: ZZ4 - 350
Hey GTA Paladin, It cost me $80 dollars labor to have the guy put my exhaust system in. He fabricated a pipe where the cat was, and did a great job installing the other parts. I bought the rest of the parts (Pipe, Muffler), he mig welded everything for me also.(No Clamps)
I into the system for a total of about $370 from the Y pipe back. Why don't you just get the factory 3inch pipe from Napa auto parts, and your muffler (Flowmaster?) and then bring it somewhere to have it installed. It wont be to bad price wise. They will just have to fabricate where the cat was.
P.S. I had a GTA with a 350 and only had one factory cat. Later
Mike
LT1Formula
Oct 8, 2015 08:34 PM
jaridjohn
Oct 5, 2015 07:01 AM
