Custom PROMs
Old Jun 26, 2001 | 01:40 PM
Ryebread1979's Avatar
Custom PROMs
I'm not sure if this is the right board to post this on, but does anyone know of any shops in central New Jersey that burn custom PROMs?
Ryan G.
Cars:
1986 Camaro IROC-Z
350TPI
1979 Camaro Sport Coupe
Unmodified 305, for sale
1993 Dodge Stealth R/T 5 speed
Complete engine rebuild
1992 Dodge Shadow Convertible
Old Jun 26, 2001 | 01:51 PM
Bort62's Avatar
79 Sport Coupe eh ?
60 Ranchero - Project ( Money Hole )
85 Sport Coupe LG4 - Daily Driver 14.82 @ 91.1 (faster than Ed)
Reader's ride -> My Ride
Just another Hot Rod kid, or thats what they all tell me.
Livin' the Stereotype
Old Jun 26, 2001 | 02:30 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old Jun 26, 2001 | 02:45 PM
Yep, it has some rust on the driver's side quarter panel. It needs a new oil pump too, the current one leaks about a quart every 3 weeks or so.
It does have a brand new A/C in it, and the rest of the engine runs smooth. Just needs some body work =P. I have new headlight/parking light bezels and a rear spoiler for it as well. $700 takes it.
Anyone know about the proms?
Ryan G.
Cars:
1986 Camaro IROC-Z
350TPI
[This message has been edited by Ryebread1979 (edited June 26, 2001).]
Old Jun 26, 2001 | 08:28 PM
Bort62's Avatar
Hmm, Leaky oil pump tooo....
Didnt know the Infamous 79 SC's came with Dry sumps...
Reader's ride -&gt; My Ride
Old Jun 26, 2001 | 09:40 PM
Ack, my mistake. I meant the fuel pump is leaking oil. Sorry.
Ryan G.
Cars:
1986 Camaro IROC-Z
350TPI
Old Jun 26, 2001 | 09:59 PM
Paul Riccioli Jr's Avatar
Car: 89 IROC-Z
Engine: 383
I don't know anyone in central Jersey who does PROM's, but if you find someone let me know. I live in Bridgewater and go to school in Trenton.
Riccioli Performance Motorworks
--RPM Racing--
-Currently building first ever engine. 383 with Super Ram plenum and runners, Edelbrock lower intake, Bosch 24# injectors, AFR 190 heads, MSD ignition.
-Will be installing Baer Brakes
-Will be installing full Spohn suspension in rear
-Art Carr 700R4 trans??
Old Jun 27, 2001 | 11:17 AM
kevinc's Avatar
Car: 1982 Z28
C&M Racing usually has a car at Englishtown during the EFI shootouts. They do custom tuning and specialize in TPI.
Can't help with contact info, sorry.
1982 Z-28
See http://www.mycar.net/mafb/registry/detail.cfm?id=276 for details
Old Jun 27, 2001 | 01:13 PM
CamaroX84's Avatar
Go to http://www.howell-efi.com
I got mine done for 150 bucks. They are good honest people. Highly recommended.
Old Jun 27, 2001 | 01:33 PM
Thanks! I'll check both places out.
Ryan G.
Cars:
1986 Camaro IROC-Z
350TPI
Old Jun 27, 2001 | 06:45 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
Your wasting your time and money. Burn your own eproms. No eprom writer can make you a custom eprom (for a reasonable price) that will work optimally with your engine combo.
For a "reasonably priced" eprom, you are only going to get a "formula" eprom based on a combo that worked reasonably well on someone that had a similar setup to you in the past. This is NOT the way to get an eprom. Every engine is DIFFERENT, based on its condition and wear. Only if you burn your own eprom will you get an optimum eprom for your setup.
PLUS, you can look at invoking Highway Mode which can save you enough gas in 1 year to pay for ALL the equipment.
Go to the DIY PROM board and read Tim's (Traxion) article on burning your own eproms. It is not hard to do, it just involves spending a little time in reading and research. If you want the "lazy man's" solution...you will get a "lazy man's" problem.
Old Jun 27, 2001 | 09:16 PM
I would love to burn my own, but I have nowhere near the time, nor the money. Plus the IROC is my daily driver, and the other 2 cars are used by other family members.
Unfortunately, its just not an option.
Old Jun 27, 2001 | 11:59 PM
Car: 89 IROC-Z
Engine: 383
I would love to learn also, but have nobody to teach me. I'm fine when it comes to mechanical work, but electricity and electronics are not my friends!!! Can you explain Highway Mode to me??
Old Jun 28, 2001 | 09:08 AM
Car: Death Mobile
Engine: 666 c.i.
The time is a couple of weekends of reading. The money is under couple of hundred dollars...the price of an "off-the-shelf" eprom.
Highway Mode is where we lean the engine from 14.7:1 to something like 16:1. With a functioning EGR this is no problem as it dilutes the mixture and makes it less volatile. I actually run 17.2-17.6:1 (depending on load) and I have had no problems in the 6 months that I have been running it. I will give a long term review in another 6 months as I would not recommend going as lean as I have unless you KNOW your engine is in good condition. One weak fuel injector...and you could toast a piston. But 16:1 is fine.
Old Jun 28, 2001 | 12:52 PM
where would be a good place to buy the equipment needed?
Old Jun 28, 2001 | 02:05 PM
Car: Death Mobile
Engine: 666 c.i.
Read this https://www.thirdgen.org/newdesign/tech/promintro.shtml
Old Jun 28, 2001 | 04:23 PM
MikeH's Avatar
Car: 90 IROC
Engine: 406
Transmission: GMPP 93/4L60
Axle/Gears: 9 bolt 3.27
look into the Haltech E6GM programable replacement computer.
Black 90 IROC, L98, A4, 323 gear. SuperRamed 406 in the works!
Linson
Oct 24, 2025 02:00 PM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
dusterbd
Sep 29, 2015 08:40 AM
