intermittent wipers dont work
Old Feb 12, 2005 | 06:09 PM
bluegoose's Avatar
Car: Firebird
Engine: 383
Transmission: 700R4, lots of Mods
Hello all,
I have a quick question about intermittent wipers. I replaced my turn signal / wiper / cruise control lever. The wipers work , slow and fast, but the intermittent does not, if I try to go to intermittent the wipers work in the slow mode in all stages. I can not check out the cruise because my cruise is disconnected, This lever was a brand new lever. The old lever worked with intermittent wipers. How can I trouble this problem. Any and all information will be greatly appreciated.
Brad
Old Feb 12, 2005 | 06:43 PM
84 Z-28 350's Avatar
Car: 84 Z-28 Camaro, 2022 2500 silverado
Engine: 383
Axle/Gears: richmond 3.73, eaton posi
at least yours work in intermetint, mine just stop, no matter where it is in it's stroke, any ideas on that one?
Old Feb 12, 2005 | 06:58 PM
bluegoose's Avatar
Car: Firebird
Engine: 383
What we could do is take parts off mine and yours and then mabe we can one working properly!!!!
Old Feb 12, 2005 | 07:24 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
You need a new wiper motor cover.
Old Feb 12, 2005 | 08:25 PM
bluegoose's Avatar
Car: Firebird
Engine: 383
wiper motor cover...hmmmm...confused..
Old Feb 12, 2005 | 09:08 PM
brutalform's Avatar
Is this the "General Wiper Motor Tech" forum?
Old Feb 12, 2005 | 09:42 PM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
I have not touched the motor or cover in my IROC, but in my winter car (1986 Pontiac) the wiper motor cover has a circuit board and a blue cam to control all the wiper functions. I lost the intermittent functions, and once I turned the wipers on, they would not turn off.
I replaced the cover, and it did the trick.
Old Feb 12, 2005 | 10:08 PM
bluegoose's Avatar
Car: Firebird
Engine: 383
Can I buy this wiper motor cover at the LAPS
Old Feb 12, 2005 | 11:09 PM
Engine: 383
uh, on mine I R2 the moter w/cover and the problem diden't go away...
Old Feb 13, 2005 | 02:37 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Did you replace it with a non-interval cover?
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
If your problem started after you changed the switch, then I'm not sure if replacing the cover would fix it.
Old Feb 13, 2005 | 10:37 PM
Engine: 383
I made sure I got the right moter P/N from autozone, I was trying to fix the same problem, and I wasen't sure where to go from there, I figured it was somthing with the wireing and I hate T/S wires.
Old Feb 14, 2005 | 01:41 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
The replacement motor came with the cover already on it?
Old Feb 14, 2005 | 01:28 PM
Engine: 383
I think so, I whish I could go look, I just remember taking off 3 bolts a clip, washer pump and a cannon plug.....if I remember correctly, anyone have a pic....remember I am in Korea and don't have acess to my car until Oct 05
Frozer!!!
Jan 19, 2024 04:55 PM
Jake_92RS
Jan 28, 2020 10:37 PM
colton_carlson
Mar 8, 2019 12:21 PM
Fronzizzle
Aug 17, 2015 02:52 PM
slade5612
Aug 11, 2015 07:19 PM
