TFS 23* vs. G2...
Old Jul 1, 2001 | 10:02 AM
Jason M 91Z's Avatar
TFS 23* vs. G2...
Well, the subject pretty much says it all. I'm in the market for a set of heads and was scared by the $1400 said and done price tag of the AFR 190's. Heres what I think I know about the G2's and 23*'s.
1.) Both have heat crossovers to retain EGR.
2.) G2 87 up can only take .5 lift, 23* can take up to .6
3.) G2's still have steel guides, 23* have bronze
4.) G2's have 67cc chambers, 23* have 64cc
5.) Both have 2.02/1.60 SS valves.
6.) 23* are available w/ CNC chambers.
Can anyone shed some light on this? Anyone have these heads on their daily driver, and if so how are they? Did you have any assembly problems like finding correct length pushrods, or bending pushrods; you know all the horror stories associated with these heads, can anybody dismis them? Thanks in advance all.
-Jason M. 1991 Camaro Z28
Old Jul 1, 2001 | 10:37 AM
KevinP92Z's Avatar
Car: 92Z, 96RamAir, 91 4X4 Burb
Engine: 383 Super Ram, LT1, 350 roller
Transmission: 700R4, Probulit 700R4 &4L60E, 4L80E
JAson, you might want to call TF and verify the guide material onthe G2's. The first generation TF twisted wedge heads had cast guides. From my notes with them, they had changed the G2's to silcon/bronze guides to eliminate the problems encountered on the early heads like I have.
Call Jim Thomasson - TF Tech advisor 330-630-1555
KevinP92Z
92 Z28 383 SLP cam,SLP headers,SLP 2ontheLeft,Trick Flow TW heads & pistons,Edelbrock base,Accel SuperRam,52mmTB,Scat Crank & forged ConnRods,MSD 6AL,SLP convertor,Baer 13/12" Track,Moser axles,Hotchkis,Genuine GM 3.42s,SLP HD Torsen,17x9" chrome SS rims
96T/A w/SLP Ram Air,SLP 2ontheLeft, Bilsteins, Baer, Hotchkis, Genuine GM, Torsen
76 4X4 Blazer 400TPI project
Old Jul 1, 2001 | 01:23 PM
MikeH's Avatar
Car: 90 IROC
Engine: 406
Transmission: GMPP 93/4L60
Axle/Gears: 9 bolt 3.27
Hey Jason.. I have the 23* heads, they are still sitting on my bedroom floor though.
FYI..Looking at my spec sheet The 23* TFS-30400004 AND TFS-30400005 heads have Sintered metal alloy guides. The 30400005s are for the 87-95 cars with the 1.260 springs. I dont know what the other one is.
Looks like To get the bronze guides you need to order the larger 1.470 springs. Which guide is better for a street car im not sure.
There is nothing to worry about as far as the pushrods go. If you get the heads they will send you a rocker and pushrod data sheet. It tells you what pushrod to use with what rocker to get the ideal geometry. You should always check it to be sure though.
Like kevin said I would call TFS and get there opinion on what would work best for your application as far as the Head,springs, and guides go. They would know better than anyone.
Both style of heads make good power from what ive seen. I hope to have my 406 running soon, I will find out then.
Good luck!
Black 90 IROC, L98, A4, 323 gear. SuperRamed 406 in the works!
Old Jul 1, 2001 | 03:13 PM
Awesome, thanks for the help guys!
Kevin, what kind of times are you running in your Z? I'm planning on almost the same top end over a 350. You must be using the big SLP cam w/ your 383 huh? My Superram is on its way, and I'm probably starting the build next month.
Mike, did you have to drill steam holes for your 406?
Old Jul 1, 2001 | 04:58 PM
Anyone else have some ideas?
Old Jul 1, 2001 | 05:09 PM
camaro6spd's Avatar
Trickflow...they sound and flow.......Trick.
Old Jul 1, 2001 | 05:35 PM
Insightful. Must be a free post huh?
Old Jul 1, 2001 | 08:13 PM
MikeH's Avatar
Car: 90 IROC
Engine: 406
Yeah... I did drill steam holes,I was a little nervous doing it though. The holes on the exhaust side were easy. It was the ones on the intake side that were a little tricky. You have to drill kinda between the chambers. At a 45* angle toward the exhaust side of the head.
3.8TransAM
Sep 17, 2015 02:16 PM
james_fearn
Aftermarket Product Review
Mar 9, 2001 09:29 PM
RCR
Mar 2, 2001 08:52 AM
BOWTIROC
Nov 1, 2000 11:12 AM
