sealing of adj. screw on aftermarket AFPR?
Old Jun 29, 2001 | 11:11 PM
james_fearn's Avatar
What do they use to seal the adjusting screw on aftermarket AFPR like cranes and accels?
Do they use liquid teflon sealant or something else?
James
1985 Z-28 305 TPI
165 ECM,STB,SFC,GW "wonderbar"
Old Jun 30, 2001 | 04:33 AM
JoelOl75's Avatar
Car: 88 Firebird WS6
I honestly didn't see anything sealing the threads on the crane.
Old Jun 30, 2001 | 09:32 PM
KevinP92Z's Avatar
Car: 92Z, 96RamAir, 91 4X4 Burb
Engine: 383 Super Ram, LT1, 350 roller
Transmission: 700R4, Probulit 700R4 &4L60E, 4L80E
Nothing is required to seal the adjusting screw. This is because the AFPR cap/spring/adjustor screw is ON TOP of the fuel pressure regulator diaphram. There is no fuel on top of the diaphram, therefore, no fuel in the cap of the AFPR.
KevinP92Z
92 Z28 383 SLP cam,SLP headers,SLP 2ontheLeft,Trick Flow TW heads & pistons,Edelbrock base,Accel SuperRam,52mmTB,Scat Crank & forged ConnRods,MSD 6AL,SLP convertor,Baer 13/12" Track,Moser axles,Hotchkis,Genuine GM 3.42s,SLP HD Torsen,17x9" chrome SS rims
96T/A w/SLP Ram Air,SLP 2ontheLeft, Bilsteins, Baer, Hotchkis, Genuine GM, Torsen
76 4X4 Blazer 400TPI project
Old Jun 30, 2001 | 09:39 PM
what about the potential of a vacuum leak?
James
Old Jun 30, 2001 | 09:50 PM
KevinP92Z's Avatar
The fine-threaded screw is a tight enough fit to the cap threads that the potential for vacuum leak is pretty minimal.
If you wanted to prove it to yourself, attach a hand vaccum pump and put a slight vacuum (don't pull too much vacuum or damage to the diaphram could occur) on the fitting and perform a short leak test to assure yourself that the screw threads aren't leaking.
However, many use a drop of loctite 222 for keeping the screw from loosening on its own, but this also will help seal the threads a little more.
KevinP92Z
Old Jul 1, 2001 | 02:26 PM
D_Amlee's Avatar
Car: 89 IROC
Engine: Yes
Transmission: That, too.
I used a small jam nut on the adjusting screw. This keeps the adjusting screw from moving once I set it, and also pre-loads the threads a bit to help seal it better.
Old Jul 1, 2001 | 02:29 PM
another question: to gain acces the the fpr are you supposed to remove the plenum or the pass. side runner?
I plan on using vaders' article to make my own afpr.
James
Old Jul 1, 2001 | 02:43 PM
Kevin Irving's Avatar
Car: 1985 Trans Am
I used regular ol' thread sealer for the threads, and I'm glad I did in case that diaphram ever ruptures. For the screw I used a small allen slug, (you can get them at any home hardware store), so I have no plenum interference issues, I just cut a 5/16 allen wrench down so that I can reach in there and adjust it in seconds. Hope this helps.
Kevin Irving
85 Trans Am WS-6, 305 TPI, custom burned '86 PROM with '87 "165"ECM, Accel Supercoil & 8.8 Wires, Rapidfire #2 @ .055", MSD 6AL, 1.6:1 Roller tipped rockers, Homemade AFPR, K&N cone, no airbox, Aluminum Driveshaft, Wonderbar, TB Coolant Bypass, Ported Plenum, Descreened MAF, Syclone Fuel Pump, JET Airfoil, Mobil 1 synth in all but transmission.
http://www.geocities.com/transam85tpi/
Old Jul 1, 2001 | 04:37 PM
KevinP92Z's Avatar
The AFPR are best changed with the plenum off. I say this because if your tool doesn't fit the security torx head just perfect, you'll have rounded heads real quick, which will require the plenumb out of the way anyway. If you alaready have changed the screws to another style head and can access them with the tools you have, then go ahead.
Old Jul 2, 2001 | 07:09 AM
JoelOl75's Avatar
The crane regulator comes with the safety torx bit.
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
roysatikas
Sep 7, 2015 08:08 PM
355tpipickup
Sep 4, 2015 05:32 PM
