How to take a crankshaft out, found tonz of parts
Old Feb 19, 2005 | 10:51 AM
crazy3rdgen's Avatar
Car: 2002 SS
Engine: Ls1
Axle/Gears: 3:42 posi
Hey i got an assembled bottom end v8. I'm going to take apart the motor where it's at. I know how to get the cam out, but i want the pistons out so i can get the crank and such. I know i have to turn the motor over and take the oil pan off then theres like U's for the pistons that go around the crank do i just unscrew them off then the piston should rise? Help me out
Old Feb 19, 2005 | 10:56 AM
White91GTA's Avatar
Car: 1991 Trans AM GTA
Engine: 5.7L TPI
why you gonna use stolen parts?
Old Feb 19, 2005 | 10:57 AM
Car: 2002 SS
Engine: Ls1
goodness
Old Feb 19, 2005 | 11:01 AM
White91GTA's Avatar
Engine: 5.7L TPI
No because according to the law that is still stealing i believe.
Old Feb 19, 2005 | 11:02 AM
Car: 2002 SS
Engine: Ls1
well anyway, how can i take out this crankshaft ***
Old Feb 19, 2005 | 11:06 AM
White91GTA's Avatar
Engine: 5.7L TPI
OK...out of curiousity, what motor is this? is it a 305 or a 350?
Old Feb 19, 2005 | 11:07 AM
Car: 2002 SS
Engine: Ls1
guessen a 350
Old Feb 19, 2005 | 11:09 AM
White91GTA's Avatar
Engine: 5.7L TPI
Dont guess...find out for sure because there will be a difference in the stroke.
Old Feb 19, 2005 | 11:11 AM
Car: 2002 SS
Engine: Ls1
well i dont think you would put a holley 750 on a 305
Old Feb 19, 2005 | 11:24 AM
Vader's Avatar
Difference in the stroke? The last time I checked, both the 305 and 350 used a 3.48" stroke. There will be a difference in the counterweights (mass), but not the stroke length.
And, FWIW, you don't actually need to remove the pistons to remove the crank. You only need to remove the rod and mains caps. (and timing chain, or course).
Old Feb 19, 2005 | 11:26 AM
Car: 2002 SS
Engine: Ls1
k thanks vader
Old Feb 19, 2005 | 11:33 AM
White91GTA's Avatar
Engine: 5.7L TPI
Thanks for the correction
Its the bore thats different...doh
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
bjpotter
Aug 12, 2015 06:06 PM
1nastygta
Aug 8, 2015 07:38 PM
antares57
Aug 6, 2015 07:47 AM
