Is it possible to take door pins out??
Old Jul 2, 2001 | 06:34 PM
Metallica383's Avatar
Is it possible to take the door pins out without taking the doors off first and if so is there some kind of special tool for this. I am talking about on a thirdgen camaro.
Whereas ye know not what [shall be] on the morrow. For what [is] your life? It is even a vapour, that appeareth for a little time, and then vanisheth away. James 4:14
Dale You were treasured in all our hearts. You will be missed #3 you were nascar!
Old Jul 2, 2001 | 06:51 PM
james_fearn's Avatar
I've replaced the bushings on the lower hinge. It was a PITA to get the pin out. I popped the spring out but in order to put it back in you will need a GM door spring tool ($<20). I used a dremel to cut the pin in half so i could work on each pressed end of the pin separately. Good luck using a punch and a hammer to remove it as easily as it looks. I had to remove my side ground effects, door sill trim, kick panels. And to replace the bushings I needed to remove the door hinge on the car side.
James
1985 Z-28 305 TPI
165 ECM,STB,SFC,GW "wonderbar"
Old Jul 2, 2001 | 07:17 PM
dhirocz's Avatar
Car: '86 IROC-Z/'94 Z28
Engine: 350 LT1/382 LT1
Transmission: 4L60-E/T-56
Axle/Gears: 3.45/3.42 (soon 4.10)
Sounds familiar. I did that, make sure you compare to the passenger side door (bushing placement). The two are different, so they should both fit snug into the hinge. Good luck trying it without the tool unless you dont mind big scratches from other prying tools in your doorjamb. A short crappy flatblade screwdriver worked here for me for knocking these loose, look in the doorjamb and you'll see what I mean.
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
Hotrodboba400
Dec 10, 2019 07:07 PM
Veaceonee
Sep 29, 2016 08:15 PM
gta892000
Sep 16, 2015 12:37 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
