Centerforce Dual Friction
Old Feb 21, 2005 | 10:41 PM
z28cmr83's Avatar
Car: 83 Z28, 84 Z28
Engine: 5.0 Cross Fire, 5.0 H.O.
Transmission: 4 Speed Auto, 5 Speed Manual
I just ordered the Centerforce Dual friction clutch yesterday, and im having second thoughts because i was reading a JEGS catalogue and it said that the centerforce I and II clutches maintained a stock clutch feel, and it didnt say it for the dual friction model. Now im running a stock L69 5 speed - 190horse 240TQ, did i make a mistake buying a clutch that is made for a much more powerful application?
Old Feb 21, 2005 | 11:56 PM
RWB____s's Avatar
Car: Z/28
Engine: 355
Transmission: Turbo 400
resurface your flywheel before installation, Install per directions
and enjoy! I ran one for a long time and the clutch feel is like stock . Its a excellent street/strip clutch.
Old Feb 22, 2005 | 12:07 AM
z28cmr83's Avatar
Car: 83 Z28, 84 Z28
so if im just running a stock settup, then what advantages will i have by getting the dual friction over the Centerforce I or II?
Old Feb 22, 2005 | 12:35 AM
z28cmr83's Avatar
Car: 83 Z28, 84 Z28
basically what i am looking for is a clutch that is better than stock, but feels stock, money isnt a problem - ive been saving long enough that i can spend it - so what is better for my setup Centerforce II or dualfriction??
again money isnt a problem and i already ordered the dualfriction - should i just install it or exchange it... am i over reacting?
Old Feb 22, 2005 | 12:38 AM
rjmcgee's Avatar
Originally posted by z28cmr83
am i over reacting?
Yes
It is an excellent clutch for your car.
Old Feb 22, 2005 | 04:46 PM
brutalform's Avatar
The D/F is just a better performance clutch. It has centrifigal weights on the "fingers", that spread out as the engine accelerates. These "fingers" are said to help put more pressure on the plate, giving the system more clamping force, leaving it less likly to slip. For your app. it is fine, youll like it. Leaves room for the power upgrades too. The other two just are not as strong as the D/F.
Old Feb 23, 2005 | 03:54 AM
smokefan's Avatar
Car: 86 IROC w/Danko bodykit, 1988 iroc vert, 1989 k1500 pickup 6" lift and 35" tires, 2002 chevy tahoe z71
Engine: 383 stealth ram, 305 tpi, 350 tbi, 5.3l
Transmission: T56, 700r4, 700r4, 4l460
IMO the D/F sucks ***. i have opps had one in my iroc and it was the pits. after about 500 miles it wouldn't grab the same. now i am running a T56 in mine so i dont know what disc i will be running yet but it is not going to be any type of centerforce
Old Feb 23, 2005 | 07:25 AM
anondude13's Avatar
It's a little sticky, but it's definately well mannered enough to get used to.
Old Feb 23, 2005 | 08:24 AM
brutalform's Avatar
Did you follow the manufacrures recommendations and "break in" the unit by driving easy for 450 miles? If you dont do this you will have problems. Everyone has their own opinion. The only problem I had was when I tried to get it to handle 500 flywheel H.P.. With my old 357 combo it worked fine, at least for me. After that I had to step up to a SPEC Stage III.
Old Feb 23, 2005 | 10:44 AM
smokefan's Avatar
no i didnt know that you had to break it in. i guess thats what i get for not reading
Old Feb 23, 2005 | 11:50 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
I've had 2 T-5 CF DFs in my 83, and I currently have a T-56 one in it. All with stock hydraulics. The T-5 ones spent most of their life behind a fairly healthy 400. They have all been absolutely flawless. Smoother and lighter pedal than stock, in fact, when driving around town or something; but they hook up hard at high RPMs. I've never had one slip.
I wouldn't let what you've "heard" scare you off. I've "heard" too, that the Earth is flat. Fortunately my hearing it didn't make it so.
I suspect that alot of the problems that you "hear" about are the result of improper installation or break-in. The product itself can work quite well, if the correct procedures are followed.
Old Feb 23, 2005 | 04:06 PM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
my dad just bought one for his cyclone project. it is going to a top loader with a 600 horse 460. this was the only clutch recommended to handle that power. it definitely shouldn't hurt a stock setup at all. if anything it is well prepared for a life ahead of it.
Old Feb 24, 2005 | 12:20 AM
Rockin-Iroc's Avatar
Car: 1986 IROC-Z
Engine: 355 ci TPI, 10:1 cr, Isky cam, ported heads, dual exhaust
Transmission: 700R4, ratchetting shifter, 3.23 rear
Anytime you use a friction material, you have to break it in. Whether it's disc brakes, drum brakes, or a clutch.
Centerforce clutches are also extremely sensitive to having everything centered and straight. You will shear off the rivits if you don't set it up properly, and if that happens, they won't honor the warrantee.
Follow the manufacturer's recommendations and you shouldn't have a problem. The weights also save leg fatigue.
Old Feb 24, 2005 | 10:47 AM
REALPOWER's Avatar
Car: 1984 Camaro on steroids/ 1987 iroc-z28 5 speed.
Engine: 383 nitrous motor / poindexter 305
Transmission: Th350
Although it could have been put in better terms, I have to agree. Mine isn't any better than the stock clutch.
91 SrS
Oct 7, 2015 04:32 PM
zman1969
Oct 1, 2015 11:09 AM
