Camshaft tool?
Ice,
That is an excellent idea. Several manufacturers offer a similar too to aid in camshaft removal and installation, and if you already have an appropriate handle, all you need is a couple of bolts.
Later,
Vader
"Let the bodies hit the floor!"
Adobe Acrobat Reader
Later,
Vader
Car: 4
Engine: 6
Transmission: 5
Actually there's a pre-existing tool already installed on the motor from the factory, just waiting for someone to need it. It doubles as the cam gear when not in use as a handle.
ICON Motorsports
ICON Motorsports
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
5/16" NC bolt. Try the spare tire hold down bolt. It should be the same size and provides a long enough handle.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z SuperPro ET Bracket Race Car
461 naturally aspirated Big Block
Best ET on a time slip: 11.242 altitude corrected to 10.89
Best MPH on a time slip: 121.52 altitude corrected to 125.89
Altitude corrected rear wheel HP: 497.9
Best 60 foot: 1.546
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Best 60 foot: 1.546
you can buy a tool for this. i did like Rb said and used a gear for years. a few years back i turned a piece of aluminum and made a handle for it on my lathe and transfered the holes from a cam sproket to get a good grip on cams when i put one in.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
ICON Motorsports
1st & 3rd
GTAman
Sep 26, 2015 02:01 PM
