grinding starter
Old Feb 25, 2005 | 03:31 PM
dukemushroom1's Avatar
Car: 1991 camaro rs
Engine: 383 stroker
Transmission: th350
grinding starter
Well I thought it was a flywheel problem but after inspecting the starter I can see that the teeth are worn down and it is not fully engaging the flywheel and is grinding. Some of the flywheel teeth are broken (and have been for a while) so my theory is that when making contact witht he broken teeth it wears down the starter teeth which then makes it so does not make contact with the good teeth. Does this make sense? I'll probably have to replace the starter and the flywheel, huh?
Old Feb 25, 2005 | 03:47 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
What block is this (approximate year model)?
Old Feb 25, 2005 | 10:43 PM
smokefan's Avatar
Car: 86 IROC w/Danko bodykit, 1988 iroc vert, 1989 k1500 pickup 6" lift and 35" tires, 2002 chevy tahoe z71
Engine: 383 stealth ram, 305 tpi, 350 tbi, 5.3l
Transmission: T56, 700r4, 700r4, 4l460
maybe you should of shimmed the starter before installing it. sound like it wasnt shimmed before install
Old Feb 26, 2005 | 12:15 AM
Car: 1991 camaro rs
Engine: 383 stroker
Transmission: th350
It's the L98 block...and it has worked fine for about a year, no problems.
Old Feb 26, 2005 | 12:47 AM
smokefan's Avatar
you most likely were chipping away at it slowly thats why you might not of noticed it. i dont know if there is a topic on shimming a starter on this board or not
Old Feb 26, 2005 | 01:04 AM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
So this is a stock starter and has worked untouched for years?
Old Feb 26, 2005 | 06:48 AM
Car: 1991 camaro rs
Engine: 383 stroker
Transmission: th350
It's a stock 350 starter that has worked fine for the last year. But I can see smokefan's point about the shims and it wearing down slowly.
Old Feb 26, 2005 | 04:20 PM
Car: 1991 camaro rs
Engine: 383 stroker
Transmission: th350
You'll never believe this...the housing for the starter was almost cracked in half. It got torqued so much somehow that it cracked. I got a new one on my warranty and it cranks again...now I just have to work out the timing issues.
3rd gen money
Oct 11, 2019 09:57 PM
Gunner242
Dec 25, 2015 04:49 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
Jlanz55
Sep 29, 2015 08:55 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
