problems w/ s-belt conversion from ta creations anyone?
Old Jul 4, 2001 | 02:24 PM
speeddevil's Avatar
i'm ordering the v-belt to s-belt kit from ta creations on monday and i was wondering if anyone had any trouble with the kit or ta creations sending them viable parts???
i read all the old posts and it looks simple but i was wondering if anyone has done this conversion on a 85 ta 305 tpi, anything to look out for or words of advice?
Old Jul 4, 2001 | 03:13 PM
John Boy's Avatar
I did this a couple of months ago and you'll be glad you did! I also got the parts from them and I was very pleased. I haven't charged my a/c back up due to the fact I can't find a connector for the compressor. I didn't get that connector or the one for the alt. from them, but auto zone had one for the alt(If you haven't orded yet I'd ask them to include the connectors.). The hardest part was getting all the old stuff off. Putting everything back on was easy since they leave everything partially assembled. Good luck.
If you happen to need the ac compressor connector like me and find one could you post the part #? Thanks.
It comes in 2 heavy boxes and shipping was like 50bux from Fl to Al.
[This message has been edited by John Boy (edited July 04, 2001).]
Old Jul 4, 2001 | 03:33 PM
speeddevil's Avatar
thanx i like to hear that! i'm going to ask for the alt and ac connectors as well, why trip out to the part store if i don't have to...
Old Jul 4, 2001 | 04:21 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Where are all these conversions coming from all of a sudden? Anyway, I think everything you need is here: Serp belt swap.
I was going to order the kit from them, but since I have "connections", I did my swap for half of what they were charging.
If you live in Southeastern US, check us out!
South East Thirdgen
GM Master Tech
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
3.73 Posi
4wheel Disc Brakes
Summit 1-5/8" headers, 2.5" Dynomax catback.
Best 1/8: 9.519@72.74
'97 Bonneville SSE
Old Jul 4, 2001 | 10:17 PM
speeddevil's Avatar
GMTech, when it rains it pours! i have a few junk yards around here but hardly any thirdgens in them... is there a part list off something else i could use to do this swap at a lower cost? if you could email me make, model and part list i would greatly appreciate it.
[This message has been edited by speeddevil (edited July 04, 2001).]
Old Jul 5, 2001 | 05:55 AM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Unfortunatly, the brackets must come from an F-body V8. The V6's won't work, and the trucks are different. The A/C compressor would hit the hood.
South East Thirdgen
GM Master Tech
Savannah, GA
'87 Trans Am
22# injectors,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
3.73 Posi
4wheel Disc Brakes
'97 Bonneville SSE
Old Jul 5, 2001 | 03:57 PM
speeddevil's Avatar
thanks for all the help, i'll let you know how it goes...
Old Jul 5, 2001 | 08:32 PM
KevinP92Z's Avatar
Car: 92Z, 96RamAir, 91 4X4 Burb
Engine: 383 Super Ram, LT1, 350 roller
Transmission: 700R4, Probulit 700R4 &4L60E, 4L80E
I used the T/A creations package to put on my 76 4x4 blazer 400 sbc TPI project.
The only problem I had was that the old style 350 vette heads I used on the 400 don't have all of the mounting holes on the ends. So a couple of bolts/studs that normally tie everything together.
But as advertised, everything was included down to all of the screws/pulleys/braces and components. Very worthwhile.
KevinP92Z
92 Z28 383 SLP cam,SLP headers,SLP 2ontheLeft,Trick Flow TW heads & pistons,Edelbrock base,Accel SuperRam,52mmTB,Scat Crank & forged ConnRods,MSD 6AL,SLP convertor,Baer 13/12" Track,Moser axles,Hotchkis,Genuine GM 3.42s,SLP HD Torsen,17x9" chrome SS rims
96T/A w/SLP Ram Air,SLP 2ontheLeft, Bilsteins, Baer, Hotchkis, Genuine GM, Torsen
76 4X4 Blazer 400TPI project
Old Jul 8, 2001 | 09:27 PM
speeddevil's Avatar
the conversion went ok, ended up getting the parts from thirdgenresource in charlotte since they were local and i needed a few other things.
now that i have the s-belt setup in place and working none of my original air-duct will fit into place. i really need some help on getting some type of air scoop, air filter box and duct work to the throttle bottle in place. does anyone know of something i could do or use? i currently have the mass air flow sensor going into the throttle body held on by a rubber coupling and this isn't going to work for long...ideas are greatly appreciated!
Old Jul 9, 2001 | 12:38 AM
John Boy's Avatar
Well I got to reuse mine since it's a camaro so I can't really help. However I believe GMTech drives a T/A so if he doesn't chime in here again you could repost over on his site.
Old Jul 9, 2001 | 06:44 PM
speeddevil's Avatar
i was wondering if i fabricated some sort of cold air intake out of stove pipe or something with the k&n filter on the end reaching down into the space where my original air box went and put my mas airflow sensor in line and skipped running the pickup scoop what kind of effect it would have on my car, 85 t/a lb9?
Old Jul 9, 2001 | 11:10 PM
speeddevil's Avatar
just searched the archives and i can't find anyone that had run into this problem... coming out of the tb is a rubber coupling that fits to a black flat air box, the mass goes to it then the stock air coffee can. my problem is since i made the swap to s-belt, i don't have room for the black flat box nor the stock air box and barely enough room for the mass sensor. if i try to install it, it rubs against the ac compressor clutch plate. i only have about 3" of space to run a pipe between the compressor and the electric radiator fan housing. anyone else had this trouble and found a solution?
smnichol86
Brakes
26
Mar 26, 2017 10:55 PM
mfp189
Sep 27, 2015 09:25 AM
KRUSS
Aftermarket Product Review
Sep 5, 2002 02:21 AM
cica55
Apr 18, 2001 07:44 PM
squidly1
Jan 10, 2001 02:30 PM
