Trouble Code help again !!!!!!!
Old Jul 9, 2001 | 07:05 PM
Brian Felts's Avatar
Car: 89 RS 355/ 89 IROC Convert
Engine: Hot Cam 355/TPI 305
Transmission: All 700r4's
Well I am getting closer....I am using a Auto X-ray and I am getting a code 42 Ignition timing monitor ( ican't find that problem)
I am also getting a code 34 Map too low
and code 33 map too high this was a scan from about 50mph in high gear.
How can I get both codes??
Brian
1989 Camaro RS
305 .030 over Hydro Pistons
Vortech heads milled to 58cc...Performer RPM intake....LT4 cam..Crane Gold rockers...FastChip custom chip...ALum. Driveshaft...3.73 gears with Posi...underdrive pullys...Rebuilt 700R4 with Vette Servo and B&M shift Kit...MSD ignition...A/C Delete No SMOG junk....1997 SS leather interior...B&M Shifter... Ultimate TBI mods...14X3 K&N open Element Non-Drop...Hooker headers....3" exhaust with Flowmaster Cross flow 16X8 Wheels from 97 RS Spohn LCA's Spohn Panhard Bar..LETS PLAY FORD!!
www.geocities.com/feltsb
Old Jul 9, 2001 | 07:34 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Hey Brian, I saw your post on TBI and thought maybe this would help.
My Haynes manual says that code 33-MAP could be:
1-leaking vacuum lines.
2-poor elec. connection.
3-open or a short in the circuit.
4-defective ECM.
Let's hope it's not the ECM.
Code 42-EST:
1- #2 above.
2- #3 above.
3- bad ignition module (I know you just replaced it, so have AutoZone test it to make sure it's not bad.)
4- #4 above.
Hope this helps.
AJ
Old Jul 9, 2001 | 07:37 PM
Hey thanks for the help. The computer is new and I am getting the code 33 & 44 thats reading one too high and one too low.
Brian
1989 Camaro RS
Old Jul 9, 2001 | 08:44 PM
AJ_92RS's Avatar
Well is it 44 or 42 damn it?
Code 44-Lean Exhaust.
1- bad injector
2- vacuum leak
3- low fuel pressure
4- bad connection, open or short circuit (I would assume at the O2 sensor or MAP sensor)
5- bad MAP sensor (duh )
6- bad O2 sensor (duh )
7- (and again) bad ECM
Sounds like a vacuum leak. That would explain both codes. A vacuum leak is really just allowing the pressure to become too high in the intake manifold. An intake manifold still has pressure, just not as high as atmospheric pressure. (Tas taught me that ) And a leak would also allow too much air in which would cause a higher than 14.7:1 A/F ratio.
I really hope you can find the prob without breaking the bank.
[This message has been edited by AJ_92RS (edited July 09, 2001).]
Old Jul 9, 2001 | 11:27 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
I think he typo'ed the "44".
Brian, two things that are in common with MAP codes and code 42...the CTS.
Monitor the CTS for any irregularities (sudden up or down swings).
This has to be monitored throught the ECM...NOT the dash gauge...different sensor.
Old Jul 10, 2001 | 04:30 PM
Thanks all who have helped. I am sorry for the typo on the 44. I do know the map too low is my falt I pulled the vac line to get a vac reading so I guess its just high. The CTS is normal with around 185* I have a 160 stat and fan switch.
Here is the vitals: Remember this was cruising at 51 MPH with the car warm.
IAC 68 steps
Map 1.70
engine RPM 1625
Throttle sensor .98 volts
o2 sensor 660 mvolts
Knock sensor 8
Brian
1989 Camaro RS
[This message has been edited by Brian Felts (edited July 10, 2001).]
Old Jul 10, 2001 | 05:47 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Brian,
You should have no knock at cruise, first I'd investigate that.
Are you getting knock counts at idle as well?
I'm assuming you didn't gun the motor up to 51 mph, then cruise it? And that the knocks came at cruise?
Old Jul 10, 2001 | 06:18 PM
Hey Thanks so much for the help!!!!!!!!! I am taking it for a ride and will repost the data when I get back........
THanks
Brian
1989 Camaro RS
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
Lmancha96
Sep 25, 2015 08:11 PM
