lt4 intake?
Old Mar 5, 2005 | 01:45 PM
WhiteKnight's Avatar
Car: 88 GTA
Transmission: Manual
lt4 intake?
Just wondering. LT1 intakes can be swapped onto TPI engines right? LT4 intakes can be swapped onto LT1 engines. So can an LT4 intake be dropped into a TPI engine? If so, any idea on what sort of gains will be made?
Old Mar 5, 2005 | 02:28 PM
rsn932's Avatar
LT4 intakes can only be put on LT1 engines that have LT4 heads. A LT4 intake could not be put on a TPI engine.
Old Mar 5, 2005 | 07:16 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
are the ports taller? just figured I would ask since this question is up
Old Mar 5, 2005 | 07:34 PM
rsn932's Avatar
Yes, I believe the LT4 intake/heads are the raised port style.
Old Mar 6, 2005 | 12:28 AM
Abubaca's Avatar
Isn't the LT4 intake just an LT1 intake made to fit the LT4 heads? ....meaning that it's no different than the LT1 intake as far as airflow?
Old Mar 6, 2005 | 12:37 AM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Probably not, the LT4 has higher "raised" port compared to the LT1.
Old Mar 6, 2005 | 04:54 PM
j88l98irocz's Avatar
Car: 88 IROC-Z twin turbo
Engine: forged 383 8-1 compression
Transmission: t56
Axle/Gears: 9in 3.50's trac loc moser axles
the lt4 will work if you get it re machined try lt1 intake.com they custom make the intakes to fit tpi engines. distributer hole/intake bolt holes ect
Old Mar 6, 2005 | 06:31 PM
Nathan Plemons's Avatar
Car: 1992 Chevrolet Corvette
Transmission: ZF-6
The LT4 intake is really only different from the LT1 in that it's matched to the LT4 heads. If you want to bolt it on I'm sure it can be modified to fit but you'd want to check your heads first. I'd say the LT1 intake will fit most applications better. The LT4 was a little strange as far as head ports go.
Bubbajones_ya
Jul 6, 2024 08:32 PM
tommy z-28
Oct 6, 2015 10:58 PM
customblackbird
Oct 1, 2015 04:30 PM
toronto formula
Sep 10, 2015 07:31 AM
e3pres
Sep 9, 2015 01:51 PM
