Reset Change Oil Lamp
Old Mar 5, 2005 | 07:29 PM
Nitro Junkie's Avatar
Just changed oil in '99 Camaro. How do you reset the "Change Oil" lamp in the dash?
Old Mar 5, 2005 | 07:46 PM
colonboy14's Avatar
Car: Trans Am
Not many people are going to know here, cause this is a THIRD gen board. You probably want to try another board for your car. And a mod is gonna yell at you.
Old Mar 5, 2005 | 07:53 PM
kevinc's Avatar
Car: 1982 Z28
Re: Reset Change Oil Lamp
1.) Turn ignition key to RUN position, but don't start it.
2.) Quickly blip gas pedal to WOT and back to idle 5x
3.) The door chime will beep 5 times rapidly to acknowledge
4.) Oil Life Monitor is now reset
5.) Use ls1tech.com or ls1.com for 4th gen car questions, this isn't the right place
Old Mar 5, 2005 | 09:09 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Take out the bulb.
Old Mar 5, 2005 | 09:45 PM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
Originally posted by Stekman
Take out the bulb.
lol
Old Mar 6, 2005 | 06:46 AM
kevinc's Avatar
Car: 1982 Z28
Take out the bulb.
It's not a bulb unfortunately. It's a small LED panel that can display a variety of messages....CHANGE ENGINE OIL, LOW ENGINE OIL, LOW WASHER FLUID, etc.
The gas pedal blip procedure is in the owners manual, 2nd least-used original equipment item on most cars.*
*the most unused original equipment item being the turn signals
Old Mar 6, 2005 | 11:04 AM
Fredless's Avatar
www.camarov6.com if your 99 is a 3800.
www.ls1tech.com www.ls1.com www.ls2.com if its an LS1.
Old Mar 6, 2005 | 07:34 PM
Thanks.
It is a 3.8L, and we don't have an owner's manual. I will have my son try these solutions when he gets home from work.
BTW - My newest vette is a C5, and my last one was a C4, but I wouldn't know a 3rd gen camaro from a 4th gen.
maroe624
Apr 16, 2017 08:29 AM
mdtoren
Aug 23, 2015 12:52 PM
Navy8125
Aug 21, 2015 09:32 AM
mdtoren
Aug 16, 2015 05:45 PM
92camaroJoe
Aug 13, 2015 06:07 AM
