Car won't start
Old Mar 9, 2005 | 06:57 PM
#32pontiac's Avatar
Car: 1988 Pontiac GTA
Engine: 350 TPI, With roller lifters
Transmission: 4 speed 700r4
Car won't start
If anyone can help, please do so. I have 88 GTA with the 350. I have done the fuel filter, the fuel pump, and it is a brand new engine. Only some times when I start the car it will fire up and run for a second, then it dies. Then I try to start it again and it won't fire. If I leave it for about an hour it will start it, and run fine for about a day and then it will do it again. If you have any suggestions please email me at boltman3001@hotmail.com
Thank you.
Old Mar 10, 2005 | 02:09 PM
sellmanb's Avatar
Car: '86 Berlinetta
is the TPI setup from a 350 TPI from a 3rd gen, or a 305 TPI? You'll probably need some new PROM burnings, ESC, knock sensor, and fuel injectors if it's from a 305....
Old Mar 10, 2005 | 05:02 PM
#32pontiac's Avatar
It is from a 350, and now the car will not start period. I am going to check my fuel filter, but like I said it is new.
Old Mar 10, 2005 | 06:34 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Sounds ignition related to me. Module, tempermental coil or pick up coil, etc.
Old Sep 12, 2011 | 06:20 PM
Jack's89GTA's Avatar
Car: 84 SC; 89 GTA T-Top; 2 87 SC T-Tops
Engine: LC1 V6; L98 V8; LC1 V6; 305
Transmission: 700 R 4; 700 R 4; 700 R 4; 700 R 4
Axle/Gears: 3.23; 4.11; 3.23; 3.27
Re: Car won't start
I rebuilt my engine last month in my 89, 350 TPI and I have replaced the started, fuel pump, and battery since and Having the exact same problem. My car would not start every now and then. Then the problem got worse. Now it will not start at ALL. HELP!!!!!!!!!
Old Sep 30, 2014 | 08:02 AM
Freekickerz's Avatar
Car: 84' Z28 camaro
Re: Car won't start
It's proboloy your carburetor... I bet you it's really dirty inside blow all the crud out or just rebuild it.... Happened to me on my 84 camaro
Old Sep 30, 2014 | 08:23 AM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Re: Car won't start
Ummmmm, Freekickerz..........it's TPI!
Old Sep 30, 2014 | 02:19 PM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
Re: Car won't start
dude, read the post. he has TPI......
Old Sep 30, 2014 | 02:24 PM
Joe Tag's Avatar
Re: Car won't start
LOL not to mention it was 3 years ago. He more than likely solved it by now.
Old Sep 30, 2014 | 02:27 PM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Re: Car won't start
Could be the Seventh Fetzer Valve sticking at times......."I'm gonna need some 3 in one oil and some gauze pads"......."Fletch", love it.
OK.....being funny here..........
Old Sep 30, 2014 | 02:29 PM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Re: Car won't start
oh man Joe,I didn't even see that! Oh well
midge54
Dec 27, 2019 04:14 PM
Brcharrelson
Aug 26, 2015 07:47 PM
justin57
Aug 20, 2015 07:05 PM
ZsTransAm
Aug 11, 2015 07:30 PM
killer777
Aug 8, 2015 02:47 PM
