Where is the TPS sensor located?
Old Jul 11, 2001 | 07:35 PM
West Coast GTA Man's Avatar
Car: 1989 Pontiac GTA Hardtop.
Engine: ZZ4 - 350
Transmission: Garbage
Hey Guys, where is the TPS sensor located on a 89 5.7 GTA? And is it expensive?
Mike
(Gran Turismo Americano) "The Ultimate Firebird"
Smokin 1989 GTA- Bone stock except for exhaust. (no catalytic-stainless pipe into Flowmaster 2 chamber).
Old Jul 11, 2001 | 07:39 PM
irocbsa's Avatar
Its screwed onto the passengers side of the throttle body and has a three wire connector plugged into it. Not sure how much they are. Used to know but I forgot. Just go to the dealer and find out. Shouldn't be more that $15 for a new Delco piece. Don't get a cheapo brand. AC Delco makes the highest quality sensors for our cars. I learned that the hard way.
bsa
"If they do not run, Then they will die." - Stonewall Jackson
'87 IROC, 355 TPI, Converted to SD, 700R4, B&M Megashifter, 3.42, Trick Flow Twisted Wedge Heads, Edelbrock Intake, Accel Runners, Comp Cam, Crane Gold rockers, Lucas 24# injectors, Edelbrock headers, Flowmaster 3'' exhaust, Mallory Ignition, Transgo Performance Shift Kit, Corvette Servo, 2,000 Stall Torque Converter
Old Jul 11, 2001 | 07:47 PM
Engine: ZZ4 - 350
Thanks Irocbsa. My car just turned 100000 miles on it, and I am changing sensors etc.. just for peace of mind. I don't know if any of these sensors etc... were ever changed. And most of them aren't too expensive. I am going to change the o2 sensor next also.
Thanks again.
Mike
Old Jul 12, 2001 | 08:02 PM
rondubbs's Avatar
make sure when you put the new sensor on you set it back to factory specs(.54Vdc) with a digital voltage meter. 89s had an adjustable tps right??
also i would never buy parts from the dealer, they overcharge, just get the ACDelco part at any parts store.
Old Jul 12, 2001 | 08:13 PM
Engine: ZZ4 - 350
Hi Ron, thanks. But how do I set that TPS Sensor voltage to factory specs with a meter?? And how do i know if mine is adjustable? It just looks like it has two screws and plugs in.
Mike
Old Jul 13, 2001 | 05:31 AM
Jza's Avatar
Jza
The holes are elongated on a radius so you can rotate the TPS.
You adjust the TPS by loosening the screws, and installing jumper wires between the connector's 3 connections. Then you measure the voltage on the A and B wires while you turn the TPS. When the voltage reads 0.54, carefully tighten the screws. Then check the voltage again (tightening the screws may move it a bit).
Old Jul 13, 2001 | 06:51 AM
Engine: ZZ4 - 350
Thanks JZA! I think I can handle that. Do I jump just the two outer wires, will they be marked a & b? I know you said there were three wires, so I was just wondering how to jump three.
Thanks man!
Mike
Old Jul 13, 2001 | 05:06 PM
Omar's Avatar
You just have to jumper the upper 2 wires.
1989 IROC-Z 5.7L
NOS 150HP kit
ProBuilt 700R4, PI Vigilante 2800 stall lockup
Baer Brakes 12" Sport System
[This message has been edited by Omar (edited July 13, 2001).]
86CamaroDan
Sep 29, 2015 10:08 PM
soarestransam
Aug 24, 2015 08:15 AM
fonzie85
Aug 13, 2015 11:50 AM
Rustyweb7
Aug 9, 2015 03:05 AM
