XM262H marine cam
Old Mar 14, 2005 | 04:07 PM
warheart's Avatar
Car: `84 Trans Am, `78 Monte Carlo
Engine: 350 TPI, 454
Transmission: T5, TH350
Axle/Gears: 3.23, 3.42 posi
XM262H marine cam
I have 305 bored 0.60 over, 2200 stall converter, 3.73 gears. Will this cam work fine with ported 416 heads and z-28 springs??
Specs: 262/268 adv. dur.
218/224 duration@.50 1.5 rockers
.462in .477ex
rpm 1300-5500
Old Mar 14, 2005 | 10:38 PM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
The cam listed will work fine with the gears, stall and springs but why are you using a marine cam? If it's free then I understand. For the best performance you should call the tech lines at the cam manufacturer. By doing this they can recommend the optimum camshaft for your application. Whether it be performance, towing, fuel economy, or all out drag racing. Oh, do you have a good compression ratio and a good intake manifold for the camshaft listed? You also will need a good flowing exhaust with headers and at least a cat-back.
Old Mar 14, 2005 | 10:46 PM
IrocZS383's Avatar
Car: 1986 Camaro
Engine: 357
Transmission: 700-R4
I also decided to go with a marine cam, I went with it because it was a retrofit roller kit and it had 112 degree lsa as opposed to the 110 lsa on the xtreme energy retrofit kit. otherwise the specs are identical to the cam for factory hydraulic roller. I went with XM276HR for a 40 over 350.
Old Mar 15, 2005 | 01:17 AM
warheart's Avatar
I have performer intake, long headers and flowmasters......
Isnīt 218@0.50 too much for the 305? I can get the cam for 30 bucks itīs almost new........
Old Mar 15, 2005 | 01:22 AM
warheart's Avatar
Oh yeah the cam is hydraulic flat tappet.... the compression must be around 9.5.
Old Mar 15, 2005 | 02:15 AM
warheart's Avatar
Some guys told me that with marine cam iīll lose my top end cause they are designed for mid range torque and thereīs also too much lift.....
Old Mar 15, 2005 | 04:59 AM
IrocZS383's Avatar
Car: 1986 Camaro
Engine: 357
i don't know about the flat tappet marine cams but check the specs against the xtreme energy cam on compcams.com
Old Mar 15, 2005 | 09:29 PM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
Honestly, I really think you should call comp cams and talk to them about a different cam. For all the work it takes to put in a cam and to not be happy with it would suck. Don't let $30.00 lure you in. Put $60.00 with it and have a better performing engine. You'll be happier.
Old Mar 15, 2005 | 09:57 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
It will be fine! The only difference from the XE262 is 112* lsa instead of 110* and alittle more lift on the exhaust. All in all it should give you a broader power curve over the XE262.
Old Mar 16, 2005 | 08:33 AM
warheart's Avatar
Thanks guys! i called compcams and they said it will work fine with my combo...........
Old Mar 16, 2005 | 08:43 AM
FullSendRacing's Avatar
Car: '85 Trans Am FAILBIRD
Axle/Gears: 4th gen torsen 3.42
that's my cam!
I used that exact cam on my 355 TPI. I've got 1-3/4 SLP headers, large chamber heads, 323 gears with a 5-speed. Honestly, for TPI I think it's too big a cam unless I go with better heads. Feels like the power's just coming on at 3k or 3500, and by that time, you don't have too long before the TPI's starting to lose breath.
also, Warheart, is that a Children of Bodom reference? Awesome tune...
Old Mar 16, 2005 | 09:37 AM
warheart's Avatar
Re: that's my cam!
Bingo!!! Yes man i love COB they are simply the best!!
Old Mar 16, 2005 | 09:54 AM
Badass. Nice to find some underground metalheads in the thirdgen crowd.
\m/ \m/
Old Mar 16, 2005 | 11:56 AM
warheart's Avatar
Iīd like to visit heavy metal festival in Finland this summer but then iīll gonna have to rob a bank or smth...
Old Mar 16, 2005 | 01:39 PM
ljnowell's Avatar
If its a flat tappet, and its not new, its not worth anything. Sure it could be reused, but why?
Old Mar 17, 2005 | 07:19 PM
Tom 400 CFI's Avatar
Engine: LT1, L400
Transmission: ZF6, T5
Axle/Gears: 3.45, 3.31
What he said. ^
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
91L98Z28
Southern California Area
Sep 19, 2015 09:35 AM
Strick1
Sep 4, 2015 07:11 AM
