How much can a 2 bolt main handle?
Old Jul 9, 2001 | 11:19 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
As it says, I'm just wondering how much hp a 2 bolt main can handle shifting at no higher than 6000rpm.
Thanks for the help
Rob
Old Jul 9, 2001 | 11:51 PM
spud's Avatar
Car: 82 & 91 Firebird
Engine: 400 & 355
Transmission: TH350 & 700
Axle/Gears: 4:11 & 2.72
I've been told "take that how you want to" A safe bet is around 400-450 hp. It could be more it could be less.
John
My 2 bolt 400 is just fine.
82 Firebird,408,Dart Iron Eagle 215's,Cam 229/239, .498/.520,TH350 Tranny, 750 Speed Demon carb, Hooker Headers(I.E. POS) Manual steering, Bfg DR's.
Check out my birds new home.
Best et 8.21 @84mph in the 1/8th
Old Jul 10, 2001 | 12:31 AM
Basett_Racing's Avatar
Spud is correct. I've seen and built some very fast 2 bolt mains before. Good aftermarket Main bolts or even better Main Studs w/ a windage will add some addition strength and added insurance. The engine I recently took out of my 82 Z28 was a 2 bolt 350, and I was able to run 12.50's(1/4) and 7.80's(1/8) with a solid cam shifting at 6600RPM and had no problems.Incorrect clearances in a hot street/strip engine(or any engine for that matter) will be the death of it way before the fact that it is a 2 bolt.
82 Z28 383, Ported 215cc Dart Iron Eagle Heads 72 cc Comb. Chambers, Comp custom grind Hyd roller cam, Speed Pro .250" domes, Wheeler Motorsports 4340 I beam rods, Eagle 5140 steel crank, Weiand Team G intake, Holley 830 DP, hedman headers
Trans: Turbo 350 w/ 4000 stall -- Rearend 7.5 w/ Richmond 4.10's, Auburn Minispool
Best ET:11.60 @ 114.56, w/ a 7.34 1/8 @ 93.50, and a 1.622 60'
89 RS, L03 305, Hypertech Chip,cat delete, Dynomax exhaust,K&N open element Filter,160 stat, MSD coil --Trans:700R4 Corvette Servo -- Rearend: 7.5 GM 3.42 w/ posi-lock
Bassett Racing
Old Jul 10, 2001 | 01:15 PM
Grand Prix's Avatar
That's a funny issue because there are lots of factors and directions to look. I am not going to give you the run of the mill "as much horsepower as you can put on the street" answer. The RPM an engine runs has alot more to do with the stress on the crank and mains than the horsepower. So keep that in mind when building the engine, 450HP at 5000RPM is less stressful than 350HP at 7000RPM. 4 bolt mains do hold the bearings better. As a result even if the 2 bolt doesn't break your bearings are going to live longer in a 4 bolt block. However, talking pure racing I have seen cast cranks ran at 9000RPM in 4 bolt blocks and forged cranks ran to 10000RPM in 2 bolt blocks. Neither of which I would expect to live terribly long. Still the bottom end was not a problem for either engine. If what you are thinking of is building a 300-450HP street engine then don't worry about the 2 bolt main. Its more important that the bores are round and straight and supported with good bolts. Personally I prefer 4 bolt mains on a street engine for above 400HP or 6000RPM. This is preferred, but far from required. The only exception being the 400. The one I have ran on the street fine with 2 bolt mains. The 400 mains are a little stronger and the 4 bolt version cracks too easily for my taste.
[This message has been edited by Grand Prix (edited July 10, 2001).]
Old Jul 10, 2001 | 03:23 PM
ws6transam's Avatar
Car: 1984 Trans Am WS6
Engine: Minirammed 385, 396 RWHP
Axle/Gears: 3.73 Moser 12-bolt
Perhaps you may simply wish to use good ARP studs and have the block line-bored. It would probably be fine for most everything you'll do short of road racing or circle track.
Daniel Burk
View my third-gen hobbyist performance page!
View my reader's ride!
'84 Trans Am WS6/L69
KB SFC, Moser axles, Torsen Diff., Spohn Adj. torque arm,
Ported 305 heads w/1.94"intake valves, Comp Cams XE262H, Griffen alum. radiator,
Turbine Technologies 2500 stall converter, underdrive pulleys, Crane Hi-6 & more.
1.05g skidpad verified.
Best of 14.039 at 100.82 MPH in Stanton, MI
New!Full 1LE brake upgrade! Details at website above.
Old Jul 10, 2001 | 03:55 PM
Jester's Avatar
According to Lingenfelter in one of his books, it doesn't really make a difference till above the 600hp level.
I'm inclined to take his word for it
"American made baby. 100% American iron. The muscle among the masses. My hero. Yep, you can take your ergonomically designed, space age, computer controlled, 4 door, cup holding map lighted split double wishbone split fold down retractable cargo covered moon roof piece of transportation and keep it. For I have felt the thunder. And I know the difference!"
JSP Motorsports
ICON Motorsports
Old Jul 10, 2001 | 05:04 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
From 1955, SBC's (small journal, no less) were run at the strip, at Daytona, Bonneville, NA, blown, turbo'd, sprayed, nitro, alcohol - basically abused in about any way you can imagine. Main bearings just never seemed to be a problem.
Then, with the advent of the mighty 350 in 1968 (a few in 1967), the 4-bolt main was born. Perhaps Chevy got the idea from Lingenfelter or Smokey, but it's also been speculated that the way they went about it actually WEAKENED the main bearing web! Even then, they still made versions with 2-bolt mains.
True, the early engines mostly had steel cranks. But, how did they avoid problems all those years?
Conclusion: If it's a streetable engine, 2-bolt is probably fine. For race engines, there are other casting problems that are more likely to bite you first.
Oh, the new Motown block is a 2-bolt...
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4. 2.93 limited slip. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/'87 LB9 block, ZZ3 cam and intake, World 305 heads, Hooker headers & y-pipe, 3" Catco cat & 3" cat-back).
57 Bel Air, my 1st car. '66 396, 9.7 CR forged TRWs, Weiand Action+, Edelbrock 1901 Q-Jet, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlocks, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Idles smooth @ 600 RPM in D. Best 15.02/95.06 @ 5800' Bandimere (corrected 13.93/102.4 @ sea level).
Old Jul 10, 2001 | 06:46 PM
Grand Prix's Avatar
...with 1/2" studs and thicker/stronger caps. Not exactly a fair comparison, its not really the # of bolts that is the important factor.
Old Jul 10, 2001 | 07:09 PM
sb406camaro86's Avatar
Car: chevy s10,1986camaro
Engine: 406sbc
Transmission: 350turbo
I have a 400 sbc that has been dyno'd at 462 hourse and 520 ft/lbs, it has a 2 bolt main has been fine for the two years that I have had it. The car is a daily driver in summer and I shift it at 6500 rpm.
Hope this helps.
Old Jul 10, 2001 | 07:43 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
I'd have to agree with spud. I've always heard 400hp, and no more that 6500rpms. But I think a massive torque set up would be more stressful. And I mean massive, like around 450lb.ft. and up.
Also like Grand Prix said, once the engine starts spinning higher, its more of a question of will the bearings take the heat and stress? But the main caps are more likely to break at lower rpms & high torque levels.
Where can you find most stock 4-bolt main blocks? In trucks, right? Usually 3/4 and 1 ton trucks. That's cause of the massive torque, plus the resistance to that torque from towing heavy payloads/trailers, etc.
Makes sense to me.
Old Jul 13, 2001 | 12:33 PM
giovanhalen's Avatar
Car: 1984 Z28
Engine: 454
Transmission: Th400
Don't forget a good balancing job.
Old Jul 13, 2001 | 01:35 PM
ede's Avatar
ede
i've done a few 2 bolt engines and have never had any problems with a few that made over 450 hp and some that were shifted at 7500. before i started worrying about the nuber of bolts in the main caps i'd pay some extra jack to have the crank blue printed, run arp bolts/studs, the block alighned honed, and maybe even some better main caps.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old Jul 16, 2001 | 07:00 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Thanks for the help everyone, it's much appreciated.
Rob
Old Jul 16, 2001 | 07:13 PM
Twin_Turbo's Avatar
<font face="Verdana, Arial" size="2">Originally posted by ws6transam:
</font>
I feel that allign boring is a waste of money, why concentrate on having it aligned to very strict tolerances when the crank will actually flex quite a bit under load??
Anyone agree?
Marck
New2Chevy
Sep 28, 2015 12:35 AM
billybob6110
Sep 23, 2015 01:30 PM
fasteddi
Sep 10, 2015 09:32 AM
angel2794
Sep 8, 2015 06:22 PM
masonta
Sep 1, 2015 06:40 PM
