'82 T/A Hp estimate?
Old Mar 19, 2005 | 07:46 PM
devestator_x's Avatar
Car: 2001 Camaro
Engine: 3800 Series
Axle/Gears: ??
I just recently put a new Edlebrock 600 cfm 4bbl carb on my LU5. the previous owner had a Holley 2bbl on it with an Edlebrock performer intake (using an adapter plate) I was just curious if this is going to make a significant difference in HP or gas milage. The A/C compressor had already been removed (wondered why the AC smelled and wasn't cold, until I looked ) I know a stock LU5 is listed at 160 HP. Other things still present ( I don't know if they matter) the charcoal canister is there (unsure it is being used) and the computer is still there (check engine light is constantly on) Thanks in Advance
Old Mar 20, 2005 | 12:43 AM
rjmcgee's Avatar
Are you sure that the distributor has been changed too? If not your not even going to make stock power levels.
Old Mar 20, 2005 | 10:23 AM
Car: 2001 Camaro
Engine: 3800 Series
Axle/Gears: ??
To be honest, I really don't know. Why would I be making less power with the stock dist? Is it a matter of needing a hotter spark? The car ran great with the 2bbl, and it sounds like it runs even better with the 4 (havent been able to drive it yet, still got a snow bank in front of it)
Old Mar 20, 2005 | 03:05 PM
rjmcgee's Avatar
I'm really not knowledgable enough on those to explain farther, hopefully some one else jumps in and helps. I have just heard that if you change to an aftermarket carb on a computer controlled carbed car then you have to go to an older HEI to have the timing advance be right.
Old Mar 20, 2005 | 07:38 PM
Mr_Happy's Avatar
Probably the ECU is in limp mode which is not very optimum for performance or economy. So a 74-81 vac advance HEI would probably help performance and economy.
Old Mar 21, 2005 | 04:47 PM
Car: 2001 Camaro
Engine: 3800 Series
Axle/Gears: ??
So what you are saying is that my ECU is currently only operating my distributer and thats all? Basically everything else has been striiped out of the car by the previous owner (cruise, A/C, crossfire F.I.) I would assume that the different trans (th350 w/ shift kit vs stock 200) would not be computer controlled. I am going to have to check if they already swapped distributers, as I have a small vac line going to the carb that doesnt look it belongs.
Old Mar 21, 2005 | 06:18 PM
Mr_Happy's Avatar
Yep
Old Mar 21, 2005 | 06:28 PM
HalfInchWrench's Avatar
Car: 85Z28 87GTA 91GTA 98SS
Engine: SBC, LS-x
Transmission: T-5, 700-R4, T-56
It isn't operating it right. You need a vacuum advance dist, not a CC one like you have now.
Old Mar 21, 2005 | 08:11 PM
Car: 2001 Camaro
Engine: 3800 Series
Axle/Gears: ??
Well thanks for the info, I am going to check tomorrow where the patch in the vac line goes. Hopefully the previous owner changed it out already. If not, any recommendations on what to replace it with? I am not too sure on what I can put on this motor as far as compatibility.
Old Mar 22, 2005 | 08:37 AM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
If you have a hose running from the carb to the distributor, then it has already been changed.
Pretty much any older 305/350 distributor would work. I got mine from a 70's Camaro for my last car.
Old Mar 22, 2005 | 03:38 PM
Car: 2001 Camaro
Engine: 3800 Series
Axle/Gears: ??
Ok thanks for the info, I checked today and it is the orginal CC dist. So that kinda sucks, hopefully I wont have much trouble finding one around here.
Old Mar 22, 2005 | 06:36 PM
Mr_Happy's Avatar
Make sure you get one that is not worn out, if the shaft flops around you will have problems...
Old Mar 23, 2005 | 11:29 AM
84L69TA's Avatar
Car: 4 Mopars total
Engine: Pentastar power
Transmission: T/F and New Process
Axle/Gears: Three 8 3/4's & one 9 1/4
So I take it the Cross-fire setup is long gone? If you do have it....I want it.
Old Mar 23, 2005 | 04:38 PM
Car: 2001 Camaro
Engine: 3800 Series
Axle/Gears: ??
Yeah, sorry. I bought the car without it and they didnt give it to me either. Of course I cant complain, Ive only put about $350 into the car so far and paid $700 for it, so anything Ive got to do doesnt bother me a whole lot as there isnt a whole lot wrong with it. So as far as my original question, after I replace the dist. any guesses on HP?
F-body-fan
Nov 4, 2015 06:13 AM
2012sergen11
Oct 13, 2015 07:38 PM
Aaronv808
Members Firebirds
Sep 30, 2015 12:55 PM
F-body-fan
Sep 23, 2015 06:36 AM
ULTM8Z
Sep 16, 2015 09:15 AM
